Hello everyone can send me the file?
Is this file still available?
Dear Impactops. I downloaded the file. Requires a password to extract.
Hi all,
I also downloaded the file but for me the password wont work, any ideas?
cheers
Has this mod been tested on newer versions of Das?
Impactops
tested on 2014/09 stil works to teachin key with the v2 file.
Best regards,
Jero
does it worc in manual mode? when i write codes by my hand on keyboard?
Hello, where you find learn key in SAM?
I haven't find.
Regards,
Hi, all coding worked on DAS2010, about 2020 stopped working, do anyone have the same problem?
thanks, hope this works
Thank you~
This is a big challenge
You're great
Thanks for the work you must have put into this.
I assume the "7.2012" is the DAS release date, in which case the mod works on 11.2012 for key coding.
I have a lot of experience of the systems outside the "black Boxes" but not what goes on inside.
Thanks again
Ah, spoke too soon.
I have the same problem as WSC (page 1)
The Immobiliser LED should come on constantly and flash off for each key programmed in.Imobiliser LED.JPG
Mine doesn't even enter the LED on stage and I'm using the V2 version.
I'd be interested to hear from WSC what, if anything, he did different.
Any advice will be appreciated.
Also, does anyone have an idea or can explain the reason for the "No log file for code numbers" means with regard to the software of the SAM/ECU immobiliser?
The SAM was changed from a V007 (I've coded keys in no problem) to a V011 unit.
Again any help will be appreciated.
Locteau (20th October, 2021)
