Thanks for the work you must have put into this.
I assume the "7.2012" is the DAS release date, in which case the mod works on 11.2012 for key coding.
I have a lot of experience of the systems outside the "black Boxes" but not what goes on inside.
Thanks again
Ah, spoke too soon.
I have the same problem as WSC (page 1)
The Immobiliser LED should come on constantly and flash off for each key programmed in.
Attachment 803796
Mine doesn't even enter the LED on stage and I'm using the V2 version.
I'd be interested to hear from WSC what, if anything, he did different.
Any advice will be appreciated.
Also, does anyone have an idea or can explain the reason for the "No log file for code numbers" means with regard to the software of the SAM/ECU immobiliser?
Attachment 806211
The SAM was changed from a V007 (I've coded keys in no problem) to a V011 unit.
Again any help will be appreciated.
