If offline SCN coding was possible could you adapt used modules into vehicle instead of new ones?
Correct thats the point and also add and remove special functions
Smart carengineer ,
yes there is that option
Smart carengineer ,
Well
i think that the coding depends from the VIN and something that i do not know when we use an used unit from example ESP unit the coding from the used will be different from the car we add it , with online the unit takes the coding from the car we have add it
a simple example
Smart carengineer ,
Does that patch work with older version 03/2012? I have 2 installs 1 or 03/2012 and 11/2011. I need to program a smart key first time ever
Smart carengineer ,
i can told you many examples and with dumps read before and after coding ,but not on public.....
Smart carengineer ,
the whole idea is like you said,correct
Smart carengineer ,
You could not use this method on a vehicle under warranty obviously and since you can't do offline SCN coding the only way is to do it online being charged by MB to do it?
correct, and thats mean we cant do the Job![]()
Smart carengineer ,
correct again ......
Smart carengineer ,
