Page 1 of 3 123 LastLast
Results 1 to 15 of 37
    Junior Member Owdalf's Avatar
    Feb 2011
    Default Starveiw 7
    I need help I have a Starveiw 7 box as been working ok apart from the usual Probs?
    Went off for a couple days ago loaded the new firmware back on.
    Yesterday however went of again: checked the firmware ( No Joy) When I checked the Network [ Only Zeros] so obviously is not connected to the internet?
    Any ideas would be appreciated. Thought it may have be the cable or lan connector tried these on my mates worked OK
    Tried my BOX on my mates setup [ Same result as on mine]
    Alf
    Sep 2008
    power off at rear,box,modem and router for 30 secs then on wait a min and enter pin to enable if needed.
    Feb 2011
    Default No Network Connection Starview 7
    I Need Help?
    I have a Starview 7 box it has been working ok apart from the usual minor problems. Went off for a couple of days loaded the New-Firmware [OK] Yesterday however went off again loaded the new firmware agai[No JOY]
    When I checked the network(ALL Zeros) So obviously NO Network Connection.
    Any Ideas would be appreciated. Thought it may have been the cable or lan Connector? Tried them on my mates [OK] Tried my box on my mates
    [No Connection]
    Feb 2011
    Already tried re/set a doz times
    Mar 2011
    you checked sub expiry date on system info,date has changed for some after updating to view 3.00
    DK Veteran lincsat's Avatar
    Jun 2008
    It's definitely an Internet connectivity problem and not the expiry or anything to do with the server. You say that you have reset the box, have you rebooted your modem and router.
    Feb 2011
    Yes: I run a wirelees Router and have 4 laptops in different rooms [No Problem getting on the Internet:
    I am using one NOW. Wonder if someting inside the BOX
    has gone Defunc.
    Feb 2011
    Should have read NO Problem getting on the WEB
    Sep 2008
    but have you powered off all units,box modem and router and use a lan cable as its direct.
    Feb 2011
    cactikid
    Yes, It looks like the BOX is Goosed: Tried Starview but got a vey poor response.
    Sep 2008
    what firmware is in system info,just to be sure 100%
    Feb 2011
    cactikid
    The latest one sent from starview: Worked OK last week
  13. #13
    same thing happened too me
  14. #14
    Sep 2008
    as you have not said what firmware is box,the latest means nothing as it may be old.
  15. #15
    Feb 2011
    cactikid
    tillymint
    View 3.00.UPS Firmware?
    Tillmint if you get sorted [Let Me Know]
