bersch8688 (2nd November, 2017), shirokov (9th November, 2017)
@manchunoe
ONLY ENGLISH !!!!!!
Hi can sameone help with change
323343km to 294500km. renault master 93c76 2011r
hi
use tachosoft like kangoo 2008;swap eeprom
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
@Nicolas9
Without Seed Key not anyone can RESET MILEAGE in Dash!I've done a A7 (kind of the same)
If not work then put backup back. Try again. Or upload file maybe someone can reset eeprom
Same Story on Audi A6 4G / VW Touareg 7P / Audi A8 2011- (New Model)
Hi there guys got a bit of a problem one of my digi progs. If i plug a epprom into the board it doesant read the mileages but the obd work fine in her. Doesant read any epproms
hi
audi a3 2009year
dp3, read km, it
storm changes km at 0 km, dash off
put it on 000
, follow the instructions when writing, remove obd dp3 and return to the menu and read it, displays 0
enter km you want and dash on and shows km
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
Memories :
Hi if someone wants Digiprog manual
is here:
THANKS....
Anachem (31st December, 2018), papaiati (7th December, 2017), rtbdiagnostic (6th December, 2017)
http://www.digital-kaos.co.uk/forums...-rtbdiagnostic your inbox is full
rtbdiagnostic (11th December, 2017)
Can Digiprog3 read eeprom 93s56 ?
@Lazkaris
Yes can Read 93S56 ;-)
So hi all,
i having a problemm, ive got here a Vw polo 6r 2012
i try'd to change the mileage, ( with digipro 3 ) i thinked it work.. but few seconds later, i got a error message in the cluster from the car
i try pull of battery not work..
i didnt write downsomewhere the orginal value to use maybe again when goes wrong..
i dont know how to fix this...
im a new user, so all help will be great !
i got vcds and digipro 3
both are not original
i did allready change seperal cars milleage with digi... this the first one i think i mess up
What about 24c64 but in atmel?
I think AT64A
Is possible to read by digiprog3?
Wysłane z mojego K920 (CN) przy użyciu Tapatalka
