Page 106 of 462 FirstFirst ... 65696101102103104105106107108109110111116156206 ... LastLast
Results 1,576 to 1,590 of 6927
  1. #1576
    Quote Originally Posted by antibisic View Post
    I think every tool from china with green pcb is better quality
    Not always my first digiprog was green PCB and it was s**t didn't wanna start up sometimes exchanged for a blue PCB abs never looked back
  2. #1577
    blackpirate's Avatar
    Jun 2009
    can anybody tell me pinouts for this?thnx
    If freedom is outlawed, only outlaws will have freedom!!!!
  3. #1578
    justy22's Avatar
    May 2009
    UK
    Quote Originally Posted by blackpirate View Post
    ST 1 clip 3M 923650-08
    1 1
    2 2
    3 3
    4 4
    19 5
    6 6
    5 7
    7 8
  4. The Following 2 Users Say Thank You to justy22 For This Useful Post:
    blackpirate (28th April, 2013), yannick1800 (28th April, 2013)
  5. #1579
    opened mine up and it has a blue pcb (click pic to enlarge)
  6. #1580
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    Quote Originally Posted by u.s View Post
    I OPENED MINE ITS A BLUE PCB BUT EVERYTHING IS COVERED IN BLACK EPOXY .....WHY IS THAT??
    Reading is fundamental, asking is easy............................
  7. #1581
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by xmodder View Post
    Probably to stop you reading the flash from chips
  8. #1582
    XmoDDeR's Avatar
    Mar 2011
    Quote Originally Posted by teerak2uk View Post
    i guess that but does anybody else have or seen that?
  9. #1583
    ALEXEI's Avatar
    chinkies are worried not to clone someone their clone
  10. #1584
    XmoDDeR's Avatar
    Mar 2011
    I BET THEN WHY EPOXY???? DOES ORIGINAL COME LIKE THAT?
  11. #1585
    XmoDDeR's Avatar
    Mar 2011
    digiprog3 cables
    anybody have the correct numbers for these cables was told the are not numbered correctly for the most part looking for cable ST 63 AND TO RE NUMBER MY CABLE SET THANKS
  12. #1586
    batandball's Avatar
    May 2011
    Don't get one with cloned black epoxy.
    If it works use it
    BatandBall
  13. #1587
    XmoDDeR's Avatar
    Mar 2011
    Quote Originally Posted by batandball View Post
    batandball explain your statement please thanks
  14. #1588
    DK Veteran chrismoore02's Avatar
    Jul 2011
    England
    Because when it goes wrong its only going one place......
    The bin
  15. #1589
    Jun 2009
    Golf 6 Plus 2010 year dash by OBD ok.
  16. The Following User Says Thank You to bochen For This Useful Post:
    shirokov (2nd May, 2013)
  17. #1590
    XmoDDeR's Avatar
    Mar 2011
    Quote Originally Posted by AvechuchoAxel View Post
    Using adapter 51 to correct Nissan Quest last week... It burned the MCU. Connections inside the adapter was wrong. Some soldering fix it!
    I think I'm about to regret my tiny investment in this tool... I have a big box full of wires and adapter, but as per my experience here in America... no a single one helped me to make my job easy. Every car I tried to do with it need to be done with memory extraction or soldering wires to MCU. GM, Ford, Honda, Nissan to name a few are done as usual with my existing and loyal tools... So in short, I didn't see yet any good reason to keep trying this tool. Perhaps it's just intended for European markets instead American...
    why did you use cable 51 and not cable 48?? they do have the same colors but 48 is for the nissan 912 where did u get your layout for this vehicle?
