Page 11 of 462 FirstFirst ... 6789101112131415162161111 ... LastLast
Results 151 to 165 of 6920
  1. #151
    DK Veteran almeida's Avatar
    Quote Originally Posted by ALEXEI View Post
    can any user confirm if DigiProg 3 work on Volvo after 2008 via obd ?
    in my case i not try yet but i?m sure it work
    today try a ford smax by odb.... 2m
  2. The Following User Says Thank You to almeida For This Useful Post:
    Nicolas9 (19th February, 2017)
  3. #152
    ALEXEI's Avatar
    here is sw for communication with pc
    is it anybody tried it ?
  4. The Following 3 Users Say Thank You to ALEXEI For This Useful Post:
    duckstar (2nd July, 2022), Nicolas9 (19th February, 2017), SALAS (28th March, 2017)
  5. #153
    justy22's Avatar
    May 2009
    UK
    this may help yoo
  6. #154
    carradio2001's Avatar
    France
    Waste your time...not working ! Maybe on genuine ?!?
    Carradio2001.
  7. #155
    Aug 2012
    Digiprog 3 can for VV polo 2000-2005 ?
    It just use obd2 cable or need take the dash off for them ?
  8. #156
    batandball's Avatar
    May 2011
    New Volvo goes by OBD tried and tested
    If it works use it
    BatandBall
  9. The Following User Says Thank You to batandball For This Useful Post:
  10. #157
    skens's Avatar
    Zagreb,Croatia
    Default dgiprog
    hi
    http://www.digital-kaos.co.uk/forums...4/#post1663143
    post digiprogIII pdf and etc
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  11. The Following 2 Users Say Thank You to skens For This Useful Post:
    kronk92 (4th February, 2017), Nicolas9 (19th February, 2017)
  12. #158
    blackpirate's Avatar
    Jun 2009
    Quote Originally Posted by batandball View Post
    2008-???
    or before 2008?
    If freedom is outlawed, only outlaws will have freedom!!!!
  13. The Following User Says Thank You to blackpirate For This Useful Post:
  14. #159
    batandball's Avatar
    May 2011
    Quote Originally Posted by blackpirate View Post
    2008-???
    or before 2008?
    2008 up
    I did V70 the other day
    and error clear works
    If it works use it
    BatandBall
  15. The Following User Says Thank You to batandball For This Useful Post:
  16. #160
    Dec 2010
    what do you think about this ?
    can be true ?
    merc e class 212 - YouTube
    why you press EZS on digiprog screen when you do mb 212?
    Why not TACHO DIAG?????
    I dont understand
    I have dp3 from elprosys and obd option you dont press ezs!!!
    Thank You
  17. The Following User Says Thank You to rukartinatv For This Useful Post:
  18. #161
    batandball's Avatar
    May 2011
    Quote Originally Posted by rukartinatv View Post
    I dont understand
    Thank You
    I think Tacho diag is for just doing dash with can blocker fitted. DP3 gives you option to do mileage with can blocker on or can blocker off
    If it works use it
    BatandBall
  19. #162
    Dec 2010
    so if i do mb 212 try obd2 i need to press ezs?
    Thank you
  20. #163
    batandball's Avatar
    May 2011
    Thank you
    same as that video
    If it works use it
    BatandBall
  21. #164
    anyone test T.U Nec dongle(working one),with this magic clone digiprog???
  22. #165
    Jul 2012
    Hi here I leave you the zip entirely of digiprog greetings
    http://www.mediafire.com/download.php?j93i835wjjvxdl8
  23. The Following 2 Users Say Thank You to gaversa For This Useful Post:
    arpi (18th February, 2018), miguel007nz (29th July, 2017)
