Hi here I leave you the zip entirely of digiprog greeting
DIGIPROG_Manual_For_reference_only.rar
kronk92 (4th February, 2017)
Tested on CAS2 direct can conection
Get vesion number then Unknown version,then get 0 and all exit
Try to read 24c64 eep ,then bloked,need to power off
I will not test that tool on 212 even with my backups made by AVDI!
Even if you can do dash ,you can never make assyst and all others location,and after odo correction you get on dash Service A,B,C .... and you cannot reset even with Xentry!,if you not make the Assyst
Even on 211 you cant make assyst by OBD.
All cables not look as in the picture,sow working with this tool its make you nervous.
Many cables is mising HC12 dongle for exemple.
Key reader....
If you make mercedes 212 how do you save the dash content?
Or CGW eprom?
You guys know if one 212 CGW will f....k with this chinese tool then you will lose evrithing,and only dealer or good tool will wake up it?
Who work with this tool,will destroy lot of dash and boys with good tools (enigma,dashcoder,Avdi,DP3) will charge lots of money for repair
I don t test on Ford my friend.
Ford can make many chep tools!
Astra-j (2009) works OK via OBD
VW Passat 2007 works OK via OBD
Astra-H works OK via CHIP
Audi A8 2007 works OK via OBD
Ford C-Max and S-Max work OK via OBD
Ford Fiesta & Focus works OK via MCU, not Dash Connector ?!?!
Golf 3 & Golf 4 works OK via dash connector and via OBD
Reading 93Cxx, 24Cxx, 95xxx, 912, 9s12 works OK.
That's for the moment ....
Carradio2001.
rtbdiagnostic (11th November, 2019)
and you read cas2 with 4 wires with digiprog?
Tested now not WORK!
Ok lets test by direct CAS conection
PS:Guys i just play for tests !
Wich is the conector for BMW CAS ALLE ?
ANd how you conect?
I mean this one
ok sow CAS and EZS canot read?
Btw in menu for 221 get mesage (use can blocker)
Connector BMW CAS ALLE not exist on Digiprog 3 clone cables !
Carradio2001.
Thats good news ,cause by dash conector tested and not work.
