Page 127 of 430 FirstFirst ... 2777117122123124125126127128129130131132137177227 ... LastLast
Results 1,891 to 1,905 of 6927
Hybrid View
    Top Poster + sashxxx's Avatar
    Jan 2013
    garage
    Moderator
    PremierD's Avatar
    Jun 2009
    Search on here for EEtool
    Moderator
    PremierD's Avatar
    Jun 2009
    you have 127888 on it mate ..
    C6E08DF11BE337C66F8CDF18BE317C63
    F8C6F18DE31BC6378C6F18DF31BE637C
    I think
    Nov 2012
    Quote Originally Posted by PremierD View Post
    I think
    I read 32x.xxx and wrote 127.888 using the car/truck function , but when I connect it in the car the dash doesn't show the total and partial mileage,nor current speed and some warning lights keep on all the time.
    The lexia tool connects with all car systems but not with the dash.
    I don't have the original dump, only the actual dump that has these problems.
    Now with the eeprom function I read this, but the Tachosoft says me to put this :
    127888km = E0C6C18D831B06370C6E18DC31B86370C6E08DC11B8337066E 0CDC18B8317063
    Then, I understand the Digi doesn't work properly.
    DigiProg III - NEC Programmer - CarProg - Vag-COM - VAG-Tacho - Vag K+Commander - DiagBox - Autocom CDP Plus - Kess V2 - KTAG - FVDI Abrites - OBDProg
    Moderator
    PremierD's Avatar
    Jun 2009
    Why ask for assistance and give the correct information after ..Tacho shit is wrong ... you have corrupted the original dump . a lesson for the future .. SAVe SAVE and SAVE again .. then change .. now you are looking for an original dump I think ..
    C6E08DC11B8337066E0CDC18B8317063
    That is 127,888 kms .. if you used digi then its wrong only the first byte was correct
  6. The Following User Says Thank You to PremierD For This Useful Post:
    z786 (20th July, 2013)
    Nov 2012
    I don't understand why for 127.888kms Digi calculates one codification, Tachosoft 23.1 calculates other and you have other different.
    Which is the program that you are using?
    Moderator
    PremierD's Avatar
    Jun 2009
    I'm using Hex workshop and Brain.exe mate ..
    Tacho shit need to be byte swapped .. Diga is just plain shit in that dump anyway .. so take your pick ..
    btw .. the algo is VDO rolling encryption .. hex inverted /16/8/4/2.. for first 4 bytes .. first nibble to last for next 4 . then byteswap the next 8 bytes .. really simple once you learn it ..
    Nov 2012
    Tomorrow I will try with your codification.
    According Tachosoft, the codification should be in thes lines:
    0000: xx xx ED F0 DB E1 B7 C3 6F 87 DF 0E BF 1D 7F 3B
    0010: FF 76 F0 ED E1 DB C3 B7 87 6F 0E DF 1D BF 3B 7F
    0020: 76 FF xx xx xx xx xx xx xx xx xx xx xx xx xx xx
    Do you agree?
  10. #9
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by djnesio View Post
    Do you agree?
    Mate .. I think I gave you the top two lines .. you need to move it one byte to the left ..
  11. #10
    please post working pinout for ST27 focus cable? no connection with supplied clone plug. thanks
  12. #11
    where can I buy it?
    Digiprog HC12 - YouTube
  13. #12
    Cardiag.ru's Avatar
    Russia
    Quote Originally Posted by olo_3 View Post
    where can I buy it?
    However, I am the good operator
  14. #13
    PETAR's Avatar
    w211 2007 not work obd
    w169 not work obd
  15. #14
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Maybe on your clone, i make a W211 2007 via obd.
  16. #15
    Mar 2013
    Europe
    Mercedes Vito 2010 Dashboard ---> 25LC640 Work Clip OK
    PS:
    Mercedes Vito 2010 EZS ---> EDR Pauli 9S12X Gold (Clone) 0L01Y Work Good
