Page 129 of 462 FirstFirst ... 2979119124125126127128129130131132133134139179229 ... LastLast
Results 1,921 to 1,935 of 6927
  1. #1921
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by carradio2001 View Post
    Which version ? Black or blue ?
    Carradio2001.
    Probably blue unit
  2. #1922
    Blue is most complete. Black I think from memory is cars upto 2004/5 pre can and Blue covers all if not most that the black covers plus cars to 2010+
  3. #1923
    DK Veteran buga37's Avatar
    USA
    Audi A8 2006 --- OBD-OK
  4. #1924
    Mar 2013
    Europe
    Citroen C5 2002 Dasboard HC08 ---> ST42 NOT WORK
    I have all testet
    - Change the Cable from Green to White / ...
  5. #1925
    hi, can this do the new prius xw 30 i think,and which chip does this cluster use?,thanks,
    also skoda octavia 2.0tdi bkd ok
  6. #1926
    Jun 2013
    Quote Originally Posted by bersch8688 View Post
    I have all testet
    it works if you change the cable from green to white?
  7. #1927
    wadim21's Avatar
    Sep 2011
    Audi A8 2008 not work.Access denied.
  8. #1928
    ok found the eeprom its a PRIUS 2011 (93C86),but probably a pain to do which other locations does it store i wonder...
    mayb it work with auris.....c86..
  9. #1929
    Quote Originally Posted by allnamesused View Post
    Try it can't cause any damage
  10. #1930
    Austria
    Anyone made volvo s80 2007?
  11. #1931
    Nov 2010
    Hi guys
    I have a problem with my digiprog, all OBD functions work but my EEPROM doesn't work just keeps saying error. Any idea how to fix?
  12. #1932
    Quote Originally Posted by OdoFix View Post
    Hi guys
    Have u tried reading them off the board?
    Also check your test clip as mine kept giving me errors and it turned out the test clip is crap
  13. #1933
    Oct 2010
    Anyone tried w203 2005 using st60 cable?
  14. #1934
    Fallen's Avatar
    Quote Originally Posted by javyb View Post
    The clips that come with it are garbage. Swap them out for Pomona ones. Until you get them, try and bend the gold contacts in toward the legs a little bit.
  15. #1935
    Nov 2010
    I tested off board same problem
    I changed the clip and same problem
    Also check the cable and cable is good and same problem.
    I'm assuming the problem is with device... Any thoughts ?
