Page 14 of 462 FirstFirst ... 49101112131415161718192464114 ... LastLast
Results 196 to 210 of 6927
  1. #196
    batandball's Avatar
    May 2011
    but you,ve been trying wrong leads on wrong units
    bound to do some damage
    If it works use it
    BatandBall
  2. #197
    diagnoza_auto2000's Avatar
    Sibiu
    Yes ,as you said maiby its first tool that i see and work in my life and i don t know the pin 1 on eprom,and i try to read eprom with Nec adaptor right?
    this is what you mean?
  3. #198
    wiseman's Avatar
    Try maybe pluging it into a car with diagnostic connector, see if it comes back to life. What amps is the 12v power supply giving out?
  4. #199
    Sibiu
    try 3 adapters and 2 cars,its not the voltage the problem.
    Inside have 7805 regulator Sow work with 11 V too
  5. #200
    Sibiu
    Inside software its not boot!
    This is why the screen remain blank
    This is the problem
    Maiby can be writed again by USB,but how?
    This problem hapens many time with X431 tester.
  6. #201
    batandball's Avatar
    May 2011
    Quote Originally Posted by diagnoza_auto2000 View Post
    Yes ,as you said maiby its first tool that i see and work in my life and i don t know the pin 1 on eprom,and i try to read eeprom with Nec adaptor right?
    where did you get nec adapter from and if u av eeprom 24c wrong way round i think that's why machine goes out off software
    you are losing me abit here
    with writing on chip right way round bottom left pin 1
    if there's a dot on chip that is pin 1
    the tapered edges on chip biggest tapered edge if edge is on bottom pin 1 left
    If it works use it
    BatandBall
  7. #202
    Sibiu
    Thank you i will start to learn from you,btw i use programmers from more then 5 years,and mostly are oem....
    You lose the point my friend.
    Only chinese sellers give a solution like this.
    When you say ,the unit not more working they answer:you don t know how to use or maiby you are wrong conected....
    C'mon
  8. #203
    wiseman's Avatar
    Diagnoza, what version is you unit 4.79 or 4.82?
  9. #204
    last time clone is can updates,now no!
    i need DIGIPROG_Manual pdf,new verison files!
    thanks!
  10. #205
    Sibiu
    i have 4.82 version when worked
  11. #206
    Sibiu
    When Digi got blocked was in Main Menu but with eprom conected,buy there is no voltage aplied to anithing even if is conected ,only when you read it or write it.
    on main menu try to press tabs but not respond,then unplug power,result was 1 digi clone dead!
  12. #207
    RMCtech's Avatar
    Mar 2011
    Open it and look for lose things, bad solders or something, you know....building quality on chinese tools is not the best.........
  13. #208
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by RMCtech View Post
    Solderings inside are good, only connectors are soldered by hand. Mine needed a hand paint also.
  14. #209
    Moderator
    PremierD's Avatar
    Jun 2009
    Neat paint job mate ... clone red? ...
  15. #210
    Sibiu
    Yes soldering are good,problem is software
