Page 141 of 462 FirstFirst ... 4191131136137138139140141142143144145146151191241 ... LastLast
Results 2,101 to 2,115 of 6927
  1. #2101
    Nov 2010
    WORKS WITH MICRONAS. TESTED WITH AUDI A3 2008.
  2. #2102
    Quote Originally Posted by superbajer View Post
    please,take off caps lock!
    br.
  3. The Following User Says Thank You to sepistar For This Useful Post:
    shirokov (14th August, 2013)
  4. #2103
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by drpeter View Post
    A Dodge Caliber 2006 is coming in tomorrow, someone tested this car with digiprog 3, chrylser 300C menu by OBD? Lot of work to remove dash. Thanks.
    Tested with digiprog, digi read the right value (+/-1000km out) tool said write ok but km not changed.
  5. #2104
    davecooper47's Avatar
    Dec 2010
    Caliber goes via BDM points with any decent tool including the digiprog clone.
  6. #2105
    carbandit's Avatar
    bonnie scotland
    Quote Originally Posted by davecooper47 View Post
    yes but the stripout is torture
  7. #2106
    Are you removed batery or fuse?
  8. #2107
    DK Veteran buga37's Avatar
    USA
    "Xmodder" the Job well done, I'm not sure what you talking about
  9. #2108
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by antibisic View Post
    no i was thinking about that but customer did not wanted errors on the dash. So i did not took the risk. And after programming i read the old value by obd so resetting would not help. I saw also that digi reset the dash also.
  10. #2109
    drpeter's Avatar
    The Netherlands
    BMW Z3 1996 connector dash connector 7 ok
  11. The Following User Says Thank You to drpeter For This Useful Post:
  12. #2110
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    Quote Originally Posted by buga37 View Post
    Dodge / chrysler has SRI memory it holds miles too digi doesn't do that so the job is not complete on some of these vehicles it will throw a CEL because the km/mls in the cluster don't match the km/mls in SRI.
    Reading is fundamental, asking is easy............................
  13. The Following User Says Thank You to XmoDDeR For This Useful Post:
    ReSiDenT3viL (15th August, 2013)
  14. #2111
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by xmodder View Post
    I have done a few 300c and never had this problem
  15. #2112
    USA
    I did test drive to make sure it's working ok, i didn't notice anything wrong, i'm sure the guy would be calling me by now
  16. #2113
    cotymoto's Avatar
    May 2009
    nissan terrano 2001 hc08 magneti marelli not working with cable 42.
  17. #2114
    Bought a Digi from this seller on Aliexpress - hxxp://www.aliexpress.com/store/111854
    when it arrived touch screen wasn't working properly and it was making an alarm sound so I opened it up to find this -
    a leg missing off the ST chip and bodged with a wire glued loosely in place.
    messaged the seller about it he said hes not sure that's not how its supposed to be
  18. #2115
    Fallen's Avatar
    Quote Originally Posted by beats2006 View Post
    Mine was EXACTLY the same.
    I did a proper repair and its now ok.
    Hopefully you have enough leg left on the chip to solder to.
