What you mean not work? By obd it Will never work take out dash and do by solder points, i did it and it worked.
Wbr Adam.
Wbr Adam.
I have a digiprog3 but some adapters inadequate wire colors as they appear in the image.for example on the adapter 51 have red,black,orange,braon on picture show braon,white,green,yelow.i dont know how to connect thanks
Polo 2008 take out dash????? What are you talking about????? this will definitely go via OBD. If it doesn't your machine is faulty.
Would chinese Digiprog III do 2009+ Skoda Superb 3T4 1.9 TDI with NEC+24c32 via OBDII?
Unfortunately I can't have this tool for testing that's why I ask if anybody done it with 2009+ Superb with NEC. I search the thread but, I can't find anything about Superb, only Octavia, Passat and other VAG cars, presume it should work also with Superb, but I had hope that someone can confirm it 100%.
easyobd (5th September, 2013)
Thanks, that's what I thought. I just downloaded user manual with pdf-s, and it's say that digiprog 3 does Superb 2008 +, but it also say that to program this dash it has to be done in two steps(manual is in german laguage, so I don't know if google correctly translate it):
1. solder some plug 47 into the dash and then connect with digiprog ....
2. conect the St 16 plug into diagnostic car port and do programming
Is that correct way to do it with Digiprog or can I go straight true OBD- soldering is not a problem for me, but reading this tread nobody mentioned abut dash preparation on VAG cars. I checked Digiprog VW Passat manual and says to same way to do the dash on Passat-but other members said that Passat went straight true OBD?
Mate .. Plug the dam thing in press read .. if it reads change it .job done ............
Thanks guys, and sorry for stupid questions, didn't wanted make you angry
PremierD you must have some nerves for people's like me![]()
rtbdiagnostic (28th April, 2021)
BMW E46 EWS3 ST35 ---> Work (Read & Write)
Anyone tested A6 (facelift) 2009-2010 dashboard with dp3 clone?
have done 2005-2008 dashes without problem
thank you in advance
Burko
