Page 151 of 462 FirstFirst ... 51101141146147148149150151152153154155156161201251 ... LastLast
Results 2,251 to 2,265 of 6927
  1. #2251
    pierre renault
    Guest
    Thank you !!
  2. #2252
    Apr 2013
    I try ford focus st27 for me is not work..
  3. #2253
    sorry for double post
    Anyone tested A6 (facelift) 2009-2010 dashboard with dp3 clone?
    have done 2005-2008 dashes without problem
    thank you in advance
    Burko
  4. #2254
    Prussia
    Quote Originally Posted by burko View Post
    Burko
    anyone tried 2013 A6 with it?
  5. #2255
    Quote Originally Posted by TULGEYWOODMAN View Post
    Works a treat mate try it!
  6. #2256
    milesbetteroff's Avatar
    Sunny Scotland
    Not work just same as 2012 wants you to do EEPROM prepare first then Diag but don't work diagprog dp3 did it 5 mins witch is not the same as 2012 it must be differant in some way but looks the same !!!!!
    Milesbetteroff here to help
  7. #2257
    smartymarti's Avatar
    Jan 2011
    cornwall
    Quote Originally Posted by milesbetteroff View Post
    I don't understand the reply mate , its 2012 but its not the same as a 2012 ??? And are they 5 minute job in total or once you. Have stripped out and prepped EPROM
    All about the Bass
  8. #2258
    2010 MB E-klass via OBD - OK
    B-Klass Tacho diag via cable ST60- ok
  9. #2259
    Is it working with Audi a3 2011?
  10. #2260
    HC08 ---> ST42 Any chance to do it with digiprog 3 ?
  11. #2261
    Quote Originally Posted by michalez View Post
    No hc08 not work with digi
  12. #2262
    Hi, after change mileage in Skoda Superb 2008 (Micronas) by OBD i have this error with VCDs 25-IMMO 00003 -Control Module Defective .
    All working fine, car start, no lights ON in cluster..but i can't erase the DTC..when i clear appears again.
    How can i fix this?
  13. #2263
    cotymoto's Avatar
    May 2009
    Where is the defect? Engine, cluster.remove battery negative 3 min and read with vag com and clear dtc.
    Enviado desde mi LT30p usando Tapatalk 2
  14. #2264
    Quote Originally Posted by cotymoto View Post
    Hi, The Fault code its in the 25-immo module
    01-Engine and 17-Cluster are fine, no DTS stored.
    Ok , thanks i?ll remove the battery and check.
  15. #2265
    Quote Originally Posted by eltiobarbas View Post
    Normal because you do mileage by obd and it cant erase all tool playing obd you will get this error
    solution is by programer for not get this error
