MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
Fiat Chroma 2006 1.9 Multijet change km via OBD perfect,Fiat Doblo 2003 benzina Read km (fiat km 1.4) write no and Digi Write perfect?
He sell v4.92 for &1100 !!!
Are VW Nec + 24c64 after 2012 working on 4.85 ver ?
I think no
serial its ok! you can order chip if its missing!
or buy update , and flash it thru external programmer!
If freedom is outlawed, only outlaws will have freedom!!!!
ill look in the morning and if its missing i will order usb chip! i do want to do the update but don't want to bugger it up as i have not got my dp3 at the minute either so i need it! if it connect to retool ok then i will think about doing the update, is the process obtain update.bin and upload using digiloader.exe? also do i need to buy the update from the supplier as I've read that each update needs to have the correct serial number in it? is this correct?
Please hit thanks if this helped you!
update comes for each sn! if you use update from other sn to your device it will damage!
you can buy 485 from supplier or get 488 from other people!
amd yes, if you got usb chip you can connect with eetool and update device via usb digiloader!
ok thanks whats the going rate for 4.88 ? is that the latest update? and also does anyone know which extra cars it will do that 4.82 won't do?
check tacho.de there is the list of updates
looks good thanks, i want 4.92 if its available, anyone on here want to give me a price for 4.92? or if its not available yet then a price on 4.88? cheers guys
someone have update 4. 88 bin for me?
want to see if it can be cracked by me.
