What about VW sharan 2006 it's working with digiprog??? Thanks for answer.
In moust case it work, but when you not try you will not know![]()
VW ecu edc15 can i do it with dp3 via obd ??
edc16 is possible for sure,
Repinator (15th January, 2014)
hi
BMW 1 (E81/E82/E87/E88) CAS 3 DIAG OBD ST16 ok
BMW_1(E81_E82_E87_E88_TACHO CHIP 35080 -Stecker 01 put new 35080 OK
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
verica (15th January, 2014)
If cable st27 is not working take the cable from dash plug witch goes to pin 10 in digi DB25 and put it like in the picture attached.Regards
Nierka19 (15th January, 2014)
I try to convert 912 to nec file but was missing some baits...
Digi can make MB Vito 2002 year Motorola 68HC908AZ60 by OBD?
no can not!
ah well .thats bollxed him up then.
Please help stamp out this disgusting trade.
JUST SIGN THE PETITION .....PLEASE
https://savedogs.soidog.org
Any one had CAN based cars communication problem with chinese DP3?
mine is v4.82, K line works ok but CAN doesnt work at all
i have changed OBD cable form tested unit,but it didnt solved probem, so im shure problem is in DP3 unit
also can someone please make quality photos of both side main board to compare components, i belive something is in wrong place or wrong value
thank you very much!
Burko
Macedonia
