Audi A6 4F UDS only dash 2011 2.0TDI - OBD 5 min OK ! Perfect !!![]()
solar (5th February, 2014)
How China is the production of three friends Digiprog device? Do you have use? What are the cons and have problems? I'm thinking of buying. Your work could help?
Thank you.
bought yanhua unit this morning, let see if it's made better than others....
Hi, need advices how to change CLS 2007 mileage. It is possible by obd first ezs 9999999 and after by obd dash?
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
You can do only Dash OBD
For EZS you need other programmer ;-)
GO GO !!![]()
Hi to all
Do anybody manage how to work with st60 on w211 and w203 dashboard??? Always dont to me
You need to search in this topic for st60 diagram ,there is a problem in db25 connector ,ground and power are on a wrong pins.
ok.today try that 2009 mondeo titanium with obd function,reads 0km,write new value,digi shows...check writen value 112500km....but nothing changes on clocks,i understand i need to do manually by eeprom(tomorrows job),now my problem is customer wants to go after to dealer to do some service and i sure they able to see real mileage.....my question where is other mileage locations(think ecu,bsi?) and how to do them.thanks
hello
can same one try nissan quashqai new version HCS12 with the new version 4.85 for the digi?
or can same one have the pinout coonection with the digi : pdf for exemple ?
Probably PCM module but on a 2009 its well out of warrenty and dealer will just change oil, filters etc and nothing more. Even if dealer saw big sticker under bonnet saying cam belt changed at a higher mileage then its nothing to do with him anyway and hell just do your service and stamp book with displayed mileage.
solar (11th February, 2014)
furthermore, if he did regular oem services, all the dates and milleage are registered in Ford database.
If in the database is registered a service yesterday, with let say 150000km, and today the car has 120000km, something's wrong ;-)
solar, you say. " i need to do manually by eeprom(tomorrows job)". Ok, 5 minutes maximum trying by OBD. 10 minutes maximum removing, clip to chip and replacing. 15 minutes in total. Why tomorrow's job? Why not do it while the car was with you? Arthur.
