then your digi wigi CAN is not good... put obd cable and measure is there connection to CAN wires trough digi... obd 6 is CAN high, pin 14 is CAN low...
Digiprog working with bmw x5 2006.?
Enviado desde mi SM-N9005 mediante Tapatalk
I give in ... is it ?![]()
MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
did you tested your digi using OBD cable and CAN comunication with car? my first digi was with not working CAN and my supplier replaced it...
...put both ST60 and OBD cables and measure CAN wires :
OBD 6 and 14 pin to ST60 18 and 17 pin, not shure wich one is high or low on dash, maybe pin18 is CAN high and pin17 is low...
W209 by obd not working too, "communication error".
update to v4.88 available for 70usd DIGIPROG 3 V4.88 Update Software
says this is only for YH version tho.
How to recognize YH
By sticker on back side.
