I guess he will ask now why 3 arrows and only two 10ohm resistors...
corrected.
gedas8899 (23rd April, 2014)
My resistors is corect was 10kom
What missing here....
Be allways Thankfull!
capacitors
Reading is fundamental, asking is easy............................
antonypaul (17th June, 2014)
the other day have an mb sprinter dash to do,i noticed that instead of 2xxxxx km has wrote 9xxxxxx,have try few times,same result.then i wrote only 22 km on it,result was 0 km.again the desired mileage,this time successfully.digiprog fw.4.88.notice that with previous fw.4.82,has never had problem on this dash.
br.
Fec001 (30th April, 2014)
Suzuki SX4 2011 ---> 24C16 Clip work (Backside from Dash)
Non lavora per fiat punto jaeger08
hey folks,recently I corrected Mercedes W211(2.8 CDI) mileage,but check engine light turned on and diagnostic tools tells particulate filter error..any ideas?
It's not your fault, it sometimes happens. Just make DPF regeneration and it will be OK.
bermuxa77 (26th April, 2014)
bermuxa77 (28th April, 2014)
Hi, what missing components and which function these are? Thank?s
Mahlzeit, was sind das f?r fehlende Bauteile und wof?r sind die? Danke
День добрый, каких компонентов не хватает и для чего они нужны? Благодарю
Witali
These elements can not be installed. This is normal.
wital555 (28th April, 2014)
