you must have proper tool for that.read the 35080 are not so difficult but erase-rewrite the mileage.better how 88diablo says,on new chip write backup then new mileage and everything will be ok.
br.
br.
Invest in r270 cheap and does the job
Renault Flunce 2010 hw to change the mileage use digi pro ,chip 24c16 i try to change the mileage when i put back cluster in car its show old mileage.
thanks.renault-fluence-india-official-picture-5_thumb.jpghi,
till know know sloution for this car kindly give me details.
Dashboard 95160, ABS same - post here if you cant work out and someone will calc for you im sure.
Peugeot 207,BSI valeo red and write O.K kabel st47 good work and dash c66 is too O.k work good?
Just out of intrest , how do you then clear the fault log history in the bsi ,you know that part that holds all the fault history with the mileage when the fault occured next to it.
I have dp3 that does this by obd ,was just wondering how you are managing to erase the fault log with digi .
easy! you start the car and disconect 5 times and conect some sensors and all is gone!
Brain!
Please explain in detail ,im very intrested.
Step 1: you start the car and disconnect and connect some sensors
Step 2: you start the car and disconnect and connect some sensors
Step 3: you start the car and disconnect and connect some sensors
Step 4: you start the car and disconnect and connect some sensors
Step 5: you start the car and disconnect and connect some sensors
wv beatle 2012 change km via obd with succes
Hi everyone,
My dp3 4.88(clone) says 'unknown version' when i try to connect with My VW polo bluemotion 2012.
When i try to erase error codes it works, but when i odo by obd it gave me that unknown version.
Am i doing something wrong?
Help would be gratefull.
Hans
Possibly you are asking a lot from a 200 Euro machine! Arthur.
everingo (25th June, 2014)
What do you mean?
The documents Mention that the polo is compatible for adjusting the odo meter...
Could you be more specific?
Don't believe everything you read! Arthur.
