Page 249 of 462 FirstFirst ... 149199239244245246247248249250251252253254259299349 ... LastLast
Results 3,721 to 3,735 of 6927
  1. #3721
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    Quote Originally Posted by grzesg76 View Post
    Digiprog no transistor U34?
    No, just a submarine U2.
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
  2. #3722
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    did 2010 lambo murcielago with digi3 93c86 in menu ----------------OK
    Reading is fundamental, asking is easy............................
  3. #3723
    digiprog doesnt do the prius gen3 properly, although it recognises the mileage address, it doesnt change it correctly causing mileage to freeze.
  4. #3724
    May 2013
    2011 insignia obd access denied
    bcm 2416 would not read or write
  5. #3725
    Quote Originally Posted by mike m View Post
    Did u desolder eeprom or try in circuit
  6. #3726
    May 2013
    always desolder tried with 4.82 and 4.88 would read the tottally wrong milage writing would change but only a fraction of required and the trip changed !
  7. #3727
    wiseman's Avatar
    Quote Originally Posted by allnamesused View Post
    Toyota algo requires a step down on the mileage bytes at the very last byte sequence, or it won't count up.
  8. #3728
    DK Veteran magdex's Avatar
    POLAND
    Mercedes Vito 2009 25LC640 clip works OK
  9. #3729
    May 2012
    italia
    Audi a5 2008 red/write obd ok
  10. #3730
    wiseman's Avatar
    Quote Originally Posted by gwee View Post
    correct, but my digiprog do that as well done so many without any problem, it changes last few bytes.
    I've seen it work and not work with digi, it depends on KM you are entering. Last one I tried was toyota AYGO, mileage not count up. Peter also made a script file that has the step Down at end to fix this issue.
  11. The Following User Says Thank You to wiseman For This Useful Post:
    gwee (14th July, 2014)
  12. #3731
    Quote Originally Posted by wiseman View Post
    Original also not work ok
  13. #3732
    Dec 2011
    benz 2014 year w204 can i do by obd2 with digiprog3 or i will use can filter
    plz help
  14. #3733
    wiseman's Avatar
    Quote Originally Posted by paul2797 View Post
    plz help
    Facelift w204 will prob fail
  15. #3734
    DK Veteran 54321's Avatar
    Can you use the non Yanhua cables with a Yanhua digiprog?
  16. #3735
    Prussia
    Isn't there a diagram somewhere showing the correct cable connections?
    Please help stamp out this disgusting trade.
    JUST SIGN THE PETITION .....PLEASE
    https://savedogs.soidog.org
  17. The Following User Says Thank You to TULGEYWOODMAN For This Useful Post:
    chrismoore02 (16th July, 2014)
