Hi there, has somebody made an Mercedes GL / X164 chassi?
If yes, what kind of steps should I do?
beti88 (7th November, 2014)
Nice thank you, should I do it while running the car or just ignitation on?
[QUOTE=Kykv;2412802]Have you later tried to check with VCDS if mileage has been changed for sure? I recommend you to do.[/
Im interested too. Please report.
looly (7th November, 2014)
hi
connect bsi peugeot 308 (T9, 2014-present)
http://www.digital-kaos.co.uk/forums...ml#post2415784
good luck
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
antonypaul (19th November, 2014), shirokov (1st December, 2014)
Mini 2007 Cas3 ---> Use BMW E90 Cas3 Diag work
Dash
Use R270 ;-)
rtbdiagnostic (11th August, 2015)
'If I helped, please click Thanks +Reputation..!'
hi any one tryed evoque by obd with this last update.
Make backup from eeprom evoque
And test by obd work or not
Report ;-)
