Page 287 of 462 FirstFirst ... 187237277282283284285286287288289290291292297337387 ... LastLast
Results 4,291 to 4,305 of 6927
  1. #4291
    May 2012
    italia
    [QUOTE = Wiseman; 2472142] La tua fortuna non era un controllo Johnson o avrebbe errore sul display [/ QUOTE]
    they are vw polo dash
  2. #4292
    Apr 2014
    Scandinavia
    DIGIPROG 4.88
    Audi A4 -2000 --> OBD OK
    BMW 328i E36 -1997 --> Stecker 6 OK
    Ford Focus -2007 --> OBD OK
    Seat Leon -2005 --> OBD OK
    Skoda Yeti -2014 --> OBD "UNKNOWN VERSION"
    Volkswagen Golf 4 -2000 & 2001 --> OBD OK
    Volkswagen Golf 5 -2009 --> OBD OK
    Volkswagen Passat -2000 & 2009 --> OBD OK
    Volkswagen Polo -1999 --> OBD OK
    Volkswagen Sharan -2000 & 2003 --> OBD OK
    DIGIPROG 3 - 4.88 YANHUA | Tacho Pro | Autocom CDP | FGTech Galletto V54 | Galletto 1260 | MPPS V13 | VCDS | Super VAG K+CAN 4.6 | INPA K+CAN | VAG K+CAN 1.4 | FIAT KM |
  3. The Following 3 Users Say Thank You to beti88 For This Useful Post:
    impuls002 (22nd January, 2018), kronk92 (31st March, 2017), shirokov (12th February, 2015)
  4. #4293
    digi men's Avatar
    Nov 2013
    EU
    DIGIPROG 3 4.94
    Audi a3 2012 ok by obd -5 min
    Audi a4 2011 ok by obd -20 min
    Audi a6 2011 ok by obd -20 min
    VW PASSAT 2012 OBD OK - 3 min
    VW PASSAT CC 2011 OBD OK -3 min
    Vw T5 modifed 2010 ok by obd -3 min
    Opel insignia 2011 tacho not ok by obd
    Stop worrying about what can go wrong, and get excited about what can go right.
    PRESS THANKS IF YOU LIKE MY POST AND IT HELPED YOU
  5. The Following 3 Users Say Thank You to digi men For This Useful Post:
    aliali18 (13th February, 2015), impuls002 (3rd June, 2015), shirokov (12th February, 2015)
  6. #4294
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by digi men View Post
    DIGIPROG 3 4.94
    Opel would go by clip if not by obd
  7. The Following User Says Thank You to teerak2uk For This Useful Post:
    digi men (13th February, 2015)
  8. #4295
    smokey08's Avatar
    Essex, UK
    v4.94 yanhua
    2014 '64 plate' passat cc obd - not ok 'unknown version'
  9. #4296
    aliali18's Avatar
    tunis - (kasserine*Kairouan)
    digiprog 3 ask for #48 plug, it has four cables that must be solder into the board, the issue is that the color of the cables that the pulg has are orange, black, brown and red and the schematic that I found in the web has white, yellow, green and red.
    thanks digital-kaos
  10. #4297
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by aliali18 View Post
    So open 25way plug and work out pin numbers and where it goes on cluster
    https://www.dropbox.com/s/q6pmyvl9ly...ctors.txt?dl=0
  11. The Following 2 Users Say Thank You to teerak2uk For This Useful Post:
    aliali18 (13th February, 2015), Faraday (13th February, 2015)
  12. #4298
    Feb 2015
    Lincolnshire
    anyone successfully done a 2014 ford focus with digiprog v4.94?
    iv tried diag but no connection
  13. #4299
    Feb 2015
    Lincolnshire
    2013 vauxhall corsa 35080 dash successfull with digiprog.
    used a new chip instead of erasing original
  14. #4300
    May 2014
    pls help bmw e46 318 dash works vith 4.88 tnx
  15. #4301
    88diablo's Avatar
    Quote Originally Posted by pero1989 View Post
    Works fine
  16. The Following User Says Thank You to 88diablo For This Useful Post:
    pero1989 (15th February, 2015)
  17. #4302
    wiseman's Avatar
    Quote Originally Posted by Dayo View Post
    Digi does not erase D80D0WQ EPROMs
  18. #4303
    digi prog i have proplem these days no connection by odd2 on canbus car any one have solution for it
  19. #4304
    securipro38's Avatar
    EU
    You should test obd cable with multimeter ,mine has this problem and I soldered cable with old DB9 cable and work gine now
  20. #4305
    from where i can buy new cable like it ?
