Page 292 of 462 FirstFirst ... 192242282287288289290291292293294295296297302342392 ... LastLast
Results 4,366 to 4,380 of 6927
  1. #4366
    Default Digiprog 3 clone questions and answers
    Serial is : 7E0A34110000
  2. #4367
    What is the latest version for clone?also can I update via USB if I have a banned serial?
  3. #4368
    Oct 2010
    Unucip please Give us this foto and ecu number from diagnosis.
  4. #4369
    hello to all i have a digiprog and i try to upgrade,i plug the usb on pc and dont work!!i open the digiprog and the ftdi missing....i install ftdi and now the digiprog is recognise but when i try to upgrade i select the port but nothing!!!any idea???
  5. #4370
    Mar 2015
    Europe
    Hi Guys, I?m New at this Job and would apreciate your advice. I?m about to buy a clone digiprog 3 with V4.94 to work via OBD some Mercedes like:
    -W211 (2007up to 2009)
    -W251(2006 up to 2010)
    -W164 (2006 up to 2009)
    In Africa i will not have assistance so PLEASE advice me where can i get Diagrams for those cars for the clone machine and if it will work.
    For what i?ve read the EZS from them after i work them will be 1.6 M km, is that correct?
    For what i see in prices this will be the best tool, am i correct?
    Thank You
  6. #4371
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by zecamaneca70 View Post
    Thank You
    Yes
    Kit comes with manuals
    Yes
  7. The Following User Says Thank You to teerak2uk For This Useful Post:
    zecamaneca70 (9th March, 2015)
  8. #4372
    Mar 2015
    Europe
    Quote Originally Posted by teerak2uk View Post
    Yes
    Yes
    First of all thank you for your answer.
    The more i read the more i get confused :/
    Some "old" posts say that has to take a CanFilter so EZS don?t put old value to dash!! and some say it does not need it at all!!
    So for example if i do a W204 (2012) and if Job is done with th Digiprog3 V4.94 (clone) the Dash Value will be "new" and EZS will be 1.6M kms or the EZS will send old Values to Dash?
  9. #4373
  10. The Following User Says Thank You to vageric For This Useful Post:
  11. #4374
    Mar 2015
    Europe
    Quote Originally Posted by vageric View Post
    Thank You for your answer.
    Please can you tell me what is a "not expensive or clone" easy to use machine(OBD would be great) to "fix" EZS values when they get those "1.6M km"
  12. #4375
    there is no cheap tool to do this. that i know only dp3(diagprog) and avdi(abritus72) can do this by obd.
    otherwise you can try with can-blockers.
  13. The Following User Says Thank You to vageric For This Useful Post:
  14. #4376
    wiseman's Avatar
    Quote Originally Posted by maxsek View Post
    Your Digi has 29f800 for flash inside. These cannot update via usb
  15. The Following User Says Thank You to wiseman For This Useful Post:
    PremierD (9th March, 2015)
  16. #4377
    Moderator
    PremierD's Avatar
    Jun 2009
    and the ones I ordered .. arrived today
  17. #4378
    Mar 2015
    Europe
    Hi, Thank you for your answer.
    Does anybody knows a clone (not expensive) of dp3 or avdi that works OBD so i can work with digiprog3 solving the EZS and otherplaces saved Kms problem?
    thank you
  18. #4379
    thank you
    Forget it pal no dp3 clone and advice clone will probably kill gateway and you will be out of business
  19. The Following User Says Thank You to javyb For This Useful Post:
  20. #4380
    Mar 2015
    Europe
    Quote Originally Posted by javyb View Post
    First of all thanks for advice.
    So, for example a W204 (2012) EZS i can do it with a Can Blocker but all the other places can be readed by MB guys if not used dp3 or avdi, is this correct or there is a "cheapest" way of bypass this?
    Thank You
