Sorry about that, mate. I copy pasted that from another forum, and it was red. I've changed it after 5 minutes or so! And the problem isn't only on Golf 4, it's on Audi A4 2005-2008 too. It's very strange from my perspective.
Golf and Audi A4 2005 4 2006 ---> OBD Work has notify members do succeed!you should search a solution.
digi quality is very different.
cotymoto (31st August, 2015), negatiw (31st August, 2015), zckariya70 (31st August, 2015)
Should I compare my motherboard with that image? And then search for a solution?
This link http://www.digital-kaos.co.uk/forums...archid=6391760 doesn't work. Thanks for the time man, I really appreciate your help!
And then,when you're finished that,please go here : Introduce Yourself
anyone did a porsche 997 by obd?
Stop getting worried about what could go wrong, and start getting excited about would could go right!
hmmmmmmm........eeprom
Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
thomas2mileage (31st August, 2015)
Hs anyone done a audi a8 with digi? 2011
hi dayo, thnx for info.
for a8 you need to prepare eeprom.. there are several people on other forum which succesfully changed mileage by preparing eeprom and then change by obd.
(prepare eeprom is neccecary.. i tried myself only obd on this car, didnt work)
does anyone know if digiprog can do mercedes slk R172? (i can see obd diag option, and no ezs option in digiprog. maybe this car dont have ezs synchronisation?)
Im assuming when you prepare eeprom is zeros it? Then the obd puts it up?
yes correct dayo.
It can do bosch also. Not a problem. And bosch works instantanious.
Those that have the wayting time are MM. 100%.
Digiwigi crack's the pin by bruteforce on MM.
It shoult work, like mine, but probably yours has a problem.
negatiw (2nd September, 2015)
I am using v4.88 digiprog clone. Today gave the warning over the 4.94 version upgrade, but the device did not start again had a blue screen. I waited a long time did not open. Home pa28f800 flash eprom I copy the contents on the card beforehand. I restored again, but did not open it again. DP must be within another front loader. Does that information? How can I recover the device back?
