I have updated 2 digiprogs , one oem v4.79 and one clone v4.88 , both to v4.94 vesion. An now both of them cannot do w212 clusters. Before they did. I think that the update software is the problem and not the device. Tried after to donwgrade the clone to 4.88 and now i have blue screen. How can i fix it?
Did you try to downgrade with the digiloader progam or did you program the two 29f800 chips directly with digi 1 and dig 2? Arthur
mariusf11 (9th July, 2015)
I tried to downgrade with the digiloader program. I have the two digi1 and digi2 bin files. Should i try to program the two 29f800 chips with a eprom programmer?
You need to get 4.92 apparently its a bit more stable .. My 4.94 has no problems with w212's ..
But from where i can get the 4.92 version. And why the oem digiprog is not working good anymore after the 4.94 update?
Yes, mark and remove the chips, noting their positions on the pcb. read and compare them to your digi 1 and digi 2 files. ERASE the chips and write the 4,88 files. Arthur.
Thanks . I will test and report.
Tam. I have 4.94 but have no problems with w212's. I don't go near them! Arthur.
Johnner (9th July, 2015)
The chinese seller sent me bad update files for both devices . From where did you get the good 4.94 update?
is the 4.94 update from cardiag.ru ok?
can i use the digiloader program to downgrade from 4.94 to 4.92?
