Please help me
Need picture volvo s60 soldering point 912gd128 a
Not 9s12.
St51 cable
Good job?
Please help me
Not 9s12.
St51 cable
Good job?
You'll find what you search here https://mega.nz/#F!A41kFDoC!_PJTqzEogjjDsR1grx4TEA
Envoy? de mon ASUS_T00J en utilisant Tapatalk
Everything will be back in order - All my respects to DK's members.
jomberykaso (8th August, 2016)
anyone help me confirm SN: FA746016000 up to 4.94
mainboard is no FT232. I have a new solder, but the computer does not recognize.
anyone have a solution?
Thank you very much
SOLVE! thank.
tucson 2008 2.0 gls petrol manual.rarHowzit guys need some help please ... see my dump files ori is 207 073km and mod file is 148 000km
I read with digiprog 4.94 and tuscon - c46 and seems fine even when I check file with tachosoft and dashboard tool
When I solder back on cluster it reads 8000km and also the on board computer displaying average consumption - kilometres till emprty etc. is also missing - any advise or something I could be doing wrong - anybody with a working dash dump for this vehicle or that can check my dump if it is fine![]()
'If I helped, please click Thanks +Reputation..!'
rtbdiagnostic (27th August, 2015)
"Tachosoft not always the best." ... thats why its known as Tachosh1t mate ..![]()
DashProg (27th August, 2015)
Your altered dump should read 148,003 mate .. so check elsewhere
ori207073 to128000km.rar
Would this algo maybe work I tried the sant? fe 93c46 - 2007 year as algo and the mileage to 128 000km from 207 073km![]()
Has anyone had any luck with using dijiprog on GMC YUKON or Escalade 2011 or 12 model. I believe these can be done via obd with tools like DSPIII. Anyone had any luck?
clusters (28th August, 2015)
cklair (29th August, 2015), rtbdiagnostic (29th August, 2015)
Digiprog 4.94
Ford Focus 2011 Keyless GO ---> EEPROM 95320 WORK
hoangtu (29th August, 2015), rtbdiagnostic (12th October, 2020), thomas2mileage (31st August, 2015)
Hello, I have a problem with my DigiProg 3. I've bought a Chinese clone and I tried it on a Golf 4. I connect the OBD cable to the car, go to car selection menu, chose the option that's needed in that situation and It shows the old km like this: OLD ? and it prompts me to give it a new value, I enter the new value, and it starts to say try 0, try 1, try 2 etc. and after a while it says NO CONNECTION. I've tried this on 3 different Golf 4 cars, a model from 2003, one from 2004 and one from 2005.
I've tried it on a Skoda Octavia II from 2005 and on a Audi A6 from 2006 and it worked on both cars.
Can it be a problem from the adapter, or from the DigiProg 3, or it just doesn't work on Golf 4. I have a friend that knows a guy who works with the same device and can change the km with digiprog on golf 4, but you know how it goes, maybe it isn't true!
Should I try to put another update on it? It's already 4.94!
Thank you very much!
