Page 335 of 462 FirstFirst ... 235285325330331332333334335336337338339340345385435 ... LastLast
Results 5,011 to 5,025 of 6927
  1. #5011
    Dufner
    Johnner's Avatar
    Éire
    It's okay......let's move on from this... everybody is now calmed down....
  2. The Following 2 Users Say Thank You to Johnner For This Useful Post:
    javyb (26th September, 2015), Shemek (28th September, 2015)
  3. #5012
    matekhr's Avatar
    Croatia
    Quote Originally Posted by salkapone View Post
    I only wrote that review board to find a bad solders on digi wigi
    I already did that but nothing changes
    I need a more specific hint.
  4. #5013
    Oct 2014
    Hello all team
    i have digiprog V4.94 clone
    please i can work Digiprog by obd BMW CAS3
    Is bmw 118D year 2012
    fOR INFO/
    Eeprom function on my Digiprog work Perfect
    I read/write 24cXX 95XXX 93CXX eeprom without problems
    I read 35080V6 ok, For write in NEW cHIPS 35080 is perfect
  5. #5014
    Quote Originally Posted by FORKAD View Post
    Hello all team
    fOR INFO/
    No you cant
  6. #5015
    Oct 2014
    Please wiht cable CAS-DIAG is working
  7. #5016
    Mar 2015
    Use rosfar red clone its better cas cable wil damage your cas
  8. #5017
    matekhr's Avatar
    Croatia
    Quote Originally Posted by matekhr View Post
    Eeprom function on my Digiprog doesn't work.
    In fact, I can read/write only 24cXX eeprom without problems, but all other eeproms give an error.
    I tested some 95XXX, 93cXX and 35080V6, all of them fails
    I use an adapter (which needed a little repair to make it work), not attached clip (which is really a garbage), and eeproms are from my home "collection", some new, some used, but all in good working condition. My other programmers don't have any problems with them.
    Have you any idea what should I check/repair to make an eeprom function work?
    Thanks in advance.
    Still need some repair ideas...
  9. #5018
    Oct 2014
    you read wiht adapter?
  10. #5019
    matekhr's Avatar
    Croatia
    Yes, I read with the attached adapter. It needs a minor repair, pin 19 on the 25-pin connector wasn't connected to pin 5 on the eeprom side, so I made the missing connection (solder a piece of wire). Now I can read/write all 24cXX eeproms, but all others fail.
    I don't know how digiprog makes internal pinout switching while you choose the eeprom type trough the menu. I tested only the voltage pins, and this part seems to be OK (for instance, I2C and SPI eeproms have Vss on pin 4, 93cXX has Vss on pin 5, and M35080 on pin 1, and Vcc is on pin 8 for all eeproms.) I can hear a relay clicking when trying to read an eeprom, but have no idea whether one or more relays is/are to click, depending on the eeprom type... any help is greatly appreciated
  11. #5020
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    hi friends i try to connect digi to eetool.iinstall driver on com 7.then start eetool and set com 7 but give me error ''gerat nicht gefunden''
    i do set pc term on digiwigi and it have ftdi inside.....
    FILE SERVICE
    REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agriculture
    Genuine WinOLS user
  12. #5021
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by aem View Post
    Change port to com 1 or 2 in device manager and try again or try this version
    https://www.dropbox.com/sh/a41rfvg9h...OQpmox7Aa?dl=0
  13. #5022
    digi men's Avatar
    Nov 2013
    EU
    When you give Pc Term on digi, dont do nothing more on digi then try(dont pres ok)
    Stop worrying about what can go wrong, and get excited about what can go right.
    PRESS THANKS IF YOU LIKE MY POST AND IT HELPED YOU
  14. The Following User Says Thank You to digi men For This Useful Post:
    aem (29th September, 2015)
  15. #5023
    aem's Avatar
    Jun 2014
    Quote Originally Posted by digi men View Post
    thanks.....this is the procedure.thanks again!!!!
    FILE SERVICE
    Genuine WinOLS user
  16. #5024
    volvo s80 2008 is it can be done with it
    many thx
  17. #5025
    Mar 2015
    hallo guys
    is there any news about digiprog 4 cloning?
