Page 352 of 462 FirstFirst ... 252302342347348349350351352353354355356357362402452 ... LastLast
Results 5,266 to 5,280 of 6927
  1. #5266
    Sep 2015
    northern ireland
    Also can anyone tell me if v4.94 can do mk3 galaxy 05 to10 via obd?
    Ok I found answer... sorry for wasting space☺
    Last edited by niallr; 19th November, 2015 at 09:42 PM. Reason: Used the search button
  2. #5267
    May 2015
    Can it do 07 Chevy suburban via old?
    Sent from my HTC One_M8 using Tapatalk
  3. #5268
    clusters's Avatar
    Mar 2015
    Canada
    Quote Originally Posted by Nymike View Post
    Can it do 07 Chevy suburban?
    Yes, if you disassemble dash and read 95080 using eeprom menu then calculate manually. Will not do it by OBD.
    Or post dump here and someone will adjust it for you. Be sure to include Km or Mi, original mileage, desired mileage and hours.
  4. The Following 2 Users Say Thank You to clusters For This Useful Post:
    DashProg (20th November, 2015), Nymike (20th November, 2015)
  5. #5269
    May 2015
    Thx. Will start working on it than.
  6. #5270
    May 2015
    Quote Originally Posted by clusters View Post
    Any chance you have pic of eprom location?
  7. #5271
    clusters's Avatar
    Mar 2015
    Canada
    Eeprom circled in red, while you're there check soldering of display Mofset circled in yellow.
  8. #5272
    May 2015
    Any chance for dash power up pins? I know iam asking a lot but still learning.
  9. #5273
    clusters's Avatar
    Mar 2015
    Canada
    Please learn how to use search functions, it has been posted before.
    http://www.digital-kaos.co.uk/forums...=1#post1679330
    Any more questions about this please start your own thread.
  10. The Following 3 Users Say Thank You to clusters For This Useful Post:
    DashProg (20th November, 2015), garabounga (20th November, 2015), memet99600 (21st November, 2015)
  11. #5274
    Nov 2015
    Mauritius
    hi does someone have dump for airbag continental 38910-61p10
  12. #5275
    DashProg's Avatar
    Jan 2013
    Here
    Quote Originally Posted by prahlad14 View Post
    Mate please move to airbag section you will get answer for your question
    Sent from my ASUS_T00J using Tapatalk
    Everything will be back in order - All my respects to DK's members.
  13. #5276
    Nov 2015
    i have a audi s8 year model 2008 and i want to know if the digiprog 3 working for the car and can change the mileage?
  14. #5277
    Quote Originally Posted by driftaren View Post
    on post #5264 you have ask the same question!
  15. The Following 2 Users Say Thank You to vageric For This Useful Post:
    memet99600 (21st November, 2015), teerak2uk (20th November, 2015)
  16. #5278
    dashradio's Avatar
    Inafield
    Quote Originally Posted by vageric View Post
    Because that is easier than plugging in and trying it !!!
  17. The Following 3 Users Say Thank You to dashradio For This Useful Post:
    memet99600 (21st November, 2015), teerak2uk (20th November, 2015), vageric (21st November, 2015)
  18. #5279
    ibratex's Avatar
    Jul 2015
    angola
    hello i saw this post somwhere i am sharing to ask if someone made these steps with digiprog on anyof E71 first generation x6 2008-2012 ????
    Newly launched V4.94 Digiprog 3 makes Digiprog 3 become the hot topic among many car enthusiasts, while what I want to share with you is “How to Adjust Mileage for BMW E71 with Digiprog 3”.
    Take my BMW E71 as an example; you can follow the steps below to adjust the mileage.
    1.Remove the instrument cluster and program of this gem.
    2. Place the READY PROGRAMMED instrument cluster in range, for example, on the passenger seat, but do not connect it to CAS programming!
    3. The diagnostic port is located in the driver’s footwall. Turn the ignition on a vehicle. Connect connector ST16 the diagnostic port and the DIGIPROG.
    4. Select the program: cars / trucks – BMW – 6 Series (E71) – CAS 3 DIAG.
    The DIGIPROG displays the old / wrong Mileage.
    5. Now you just confirm with the hook. (Note: Please Do Not enter new value)
    Pay attention to the display from Digiprog. If the message appears: IKE INSTALLATION must be installed within 60 seconds, the IKE (instrument cluster) or connect to the vehicle. Now a timer is running from (110-0).
    6. The instrument cluster now shows the new / correct KM – to stand.
  19. #5280
    Mar 2013
    Europe
    Digiprog v4.94
    BMW E46 2004 ---> 35080 Clip Work
    Ford Fiesta HCS12 ---> ST48 Work
    Seat MII 2013 ---> OBD Work
  20. The Following User Says Thank You to bersch8688 For This Useful Post:
