Page 36 of 462 FirstFirst ... 2631323334353637383940414686136 ... LastLast
Results 526 to 540 of 6927
  1. #526
    Sep 2012
    If it read fine it should Have worked... try another year as listed above. What error or message did your machine give?
  2. #527
    wiseman's Avatar
    Dash fuses may need to come, then it may work, some Audi a8's need this
  3. The Following User Says Thank You to wiseman For This Useful Post:
    jkschen (25th May, 2013)
  4. #528
    for the audi a4 2008 demand 1 min for reading and 30min for writing
    a4 2008 30min job work ok by obd
  5. #529
    DK Veteran almeida's Avatar
    Better next time
  6. #530
    Sep 2012
    Quote Originally Posted by wiseman View Post
    Even some A6's need fuse out with Enigma... so could be the case... take it out for 20 seconds and then back in next time.
    I did a Audi A8 with Digiprog clone by obd the other day... worked perfect... it was 2008.
  7. #531
    wiseman's Avatar
    Quote Originally Posted by enigmauk View Post
    How long was reading and writing?
    A friend of mine has a Digiprog and tried it on a polo RB8 Earlier worked fine, went to try his 2010 VW t5 van and it wont read now, but it did before. This van runs UDS not CAN, any ideas?
  8. #532
    Sep 2012
    It was only a few minutes max
  9. #533
    batandball's Avatar
    May 2011
    Tell your mate to look at post 95
    If it works use it
    BatandBall
  10. #534
    wiseman's Avatar
    Quote Originally Posted by batandball View Post
    I forgot about this issue, I bought a plug kit aswell but havent used it.
  11. #535
    South Africa
    Tested:
    Vw polo 6r 2011 obd OK
    VW lupo obd OK
    Then I try vw golf 6 2010 unit switches off
    Also try 2001 audi a4 and unit switches off
    Anyone have similar problem with digiprog?
  12. #536
    Dec 2010
    italy
    i have enigma, this digiprog clone which functions has more than enigma? for example make ajustment in service history on zgw? thank
  13. #537
    Sep 2012
    This is not a replacement to enigma it is a clone tool not a pro tool.
  14. #538
    Dec 2010
    italy
    i know, i have original enigma, but not have function for service adap'tation in zgw, if this clone can do it i buy...
  15. #539
    smartymarti's Avatar
    Jan 2011
    cornwall
    Think you might have overlooked the support issue , at least with pro tool you have some assistance even if limited some is better than none
    All about the Bass
  16. #540
    Sep 2012
    You can edit Assyst using digiprog but it isnt very good... i would edit it using AVDI or other tool...
