Page 377 of 430 FirstFirst ... 277327367372373374375376377378379380381382387427 ... LastLast
Results 5,641 to 5,655 of 6927
Hybrid View
    Jan 2016
    Quote Originally Posted by zix1 View Post
    How do i find out?
    see image for chip.
    Jan 2017
    No it doesnt (((((
    Could i buy one and solder it on top?
    ascrap2003's Avatar
    Sep 2016
    Texas
    I have a digiprog 4.88 coming in should I modify it when it arrives? resolder joints on board etc? read or back up any files? replace connectors?
    Sep 2015
    northern ireland
    2009 audi a4 b8 reads miles but won't write new miles trough obd
    Sent from my SM-G900F using Tapatalk
    autocargo's Avatar
    Hello. My digiprog not booting anymore... I suspect the problem is CY7C1049d-10VXI memory as found in many cases. Fault has started randomly not booting but after repeatedly power on/off would finally boot... Now looking at mouser website to order replacement chips but this part no longer available... there is other parts (quite a few) but not sure witch one is compatible. Nearest by numbers is CY7C1049G-10VXI... I was comparing datasheets and looks identical, but still not 100% sure... Any recommendation, maybe other producer that has been tested and 100% compatible? Thanks in advance.
    Oct 2015
    Quote Originally Posted by autocargo View Post
    http://www.newark.com/cypress-semico...rfnonsku=false
    If I help you don't forget thanks button
    Sep 2015
    Is it possible to update original Digiprog3 from version 1.32 to 4.94?
    Jan 2016
    Insignia 2009 -> acces denied (x-tool work ok)
    porsche 997 gt3 2008 obd ok.
  9. The Following User Says Thank You to mileage1 For This Useful Post:
    dritan (8th February, 2017)
  10. #9
    Jan 2017
    IN CIRCUIT
    Car 2014 VW Tiguan Diesel OBD2 OK DIGIPROG 3 CLON
  11. The Following User Says Thank You to harold1987 For This Useful Post:
    dritan (20th February, 2017)
  12. #10
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    Fiat grande punto 2012 obd with (fiat doblo 2007->) read ok write ok
  13. #11
    Mar 2016
    Has anyone tried lexus rx450h 2016 with digiprog ?
  14. #12
    Aug 2015
    BEHIND YOU
    Quote Originally Posted by Jp4ubaby View Post
    read eeprom and post dump and i will give you the desired mielage
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  15. #13
    Mar 2016
    Quote Originally Posted by eliaselias View Post
    Hey i dont know how to upload dump to site. Im beginer learning. I dont if my clonw 4.94 can connect to pc. I have only done cars with programers only.
  16. #14
    Aug 2015
    BEHIND YOU
    tell me wich mileage you need to make the file for you
  17. #15
    Mar 2016
    I dont have the car yet. Ill get it end of week. Im just asking you guys if it can be done with digiprog.
