Page 39 of 462 FirstFirst ... 2934353637383940414243444989139 ... LastLast
Results 571 to 585 of 6927
  1. #571
    batandball's Avatar
    May 2011
    If you watch DP3 (Diagprog3) doing a E / C Class Merc the clocks go upto 999999 miles then goes to the mileage you put in
    If it works use it
    BatandBall
  2. #572
    i try old 912 bsi 307 with this tool and now bsi dead(wipers,light on when you turn on ignition+cant connect pp2000).....try FFFFF no work bsi dead.maybe bad look,maybe tool....did more then 20 cars(mainly by eeproms japaneese makes with no problem)....i hate this tool because he cant save original file...
  3. #573
    Oct 2010
    diagprog, does go to 999999 but when checked with star it inputs the required km, touch wood, I've done over 50 mercs with dp3 & haven't messed one up. - dont get it wrong for the price digiprog is good but come on, don't compare to diagprog or something of that level its seriously not smart.. diagprog for mercs has more software supported versions then AVDI,
    The 50 +mercs ive done alone paid for my dp3, the rest was for free.
  4. #574
    batandball's Avatar
    May 2011
    Quote Originally Posted by solar View Post
    User error
    You can save original data with this tool. So I put that down to you
    not using it right.
    Picture attached
    I've done 912 peuget ECU with Digiprog
    EEPROM
    Set type
    912
    Read
    Save
    If it works use it
    BatandBall
  5. #575
    batandball's Avatar
    May 2011
    Quote Originally Posted by sparkz02 View Post
    Sparkz02
    I'm not comparing one machine with another, I know Merc 204 / 212 works with this, some one said in a earlier post about 204 / 212 been messed up by his friend with this tool, BUT a user of Digiprog as not mentioned it messing one up yet ?. The member that mentioned not been able to save original data obviously as,nt had a good look round this tool, can't believe he changed data without saving original 912 data that's asking for trouble, any machine can put data error in a dash or bsi.
    Lots of people like to slag this clone cos they paid thousands for original tool but that don't make you good at clocker. Most of the things that don't work on Digiprog clone is down to crap leads
    If it works use it
    BatandBall
  6. #576
    Aug 2011
    Agree with that need save first not once me reather save it 2-3 times this tool is good for experienced users with some other tools if this only tool me wouldnt do anything with it.
    And also sugest keep it away from cas modules and ezs.
    Use rosfar r270 and etl for fix is still something go wrong
    anyway think obd should all work fine.
  7. #577
    batandball,
    thanks,somehow i not see save function beforeyes,was user error(because not save),and bsi error because she dead(not because bad read-write,just dead......replace with another one,try tool again,works 100%.
  8. #578
    honingkoning's Avatar
    Dessert
    batandball,
    Bad luck, shit happens but good clone ***128515;.
    Regards Adam.
  9. #579
    LT & ES
    I saw few times "Voltage too high" on the screen after boot and screen freezing. With own power adapter and another one. Is it reason of worries? Must I change some power stabilizers inside the box? Saw Pcb and solderings looks OK.
  10. #580
    Aug 2011
    Me also get voltage to high sometimes but all work normal
    tried clio mm hc 08 today for test get error or sometimes machine freeze tried lift green cable aswell also not work
    but this trouble my other machine aswell carprog normall
    works but that also work cluster diagnosis.
  11. #581
    koziolek's Avatar
    Under the car
    so over all is this machine worth $400?
  12. #582
    batandball's Avatar
    May 2011
    Quote Originally Posted by koziolek View Post
    I think your on the wrong forum, for jokes go on sickipedia.
    I've spent more on my iPhone
    I would post link on here but PremierD might give me a bollocking
    If it works use it
    BatandBall
  13. #583
    Moderator
    PremierD's Avatar
    Jun 2009
    But is it a clone ... or original ...... ?
  14. #584
    batandball's Avatar
    May 2011
    Quote Originally Posted by PremierD View Post
    Original
    I got it when I was on holiday in Thailand, when I was with my new good looking Thai bride !!!!!!
    Are we on about bride or phone ?????
    If it works use it
    BatandBall
  15. #585
    Moderator
    PremierD's Avatar
    Jun 2009
    I would imagine it was the phone mate .. as you forgot to tell me you were married ...
