[Quote = kubuswujo; 2927537] mi metter? un altro domani tachimetrica e pubblicher? ci? che era sbagliato, e se ? risolto.
Grazie[/ quote]
Read wiit carprog A4. Version 4.74 carprog correct change
1 white
2 yellow
3 brown
4 blue
5 gray
6 green
Hi guys... need help to find which chip is the odometer for this rb8 crypto from lp 570 sts. Thank you
I have a clone digiprog 3 i cant find the st19 cable can somebody show a picture of it ?
Top of the page, search thread option. Use it please.
If you had you find this.....
http://www.digital-kaos.co.uk/forums...=1#post1929823
kronk92 (4th April, 2017)
Hi can u upload a picture of the cable st19 i have digiprog 3 clone buth i cant the cable thanks
hey guys..I can't change KM to Mile on cluster Land Rover Discovery 2 2003.I was doing correction of mileage and couple of time I was changing the mileage because I tried to make it same (cluster and BCU)! And now I can't to change from Km to mile..
Any solution ? thank you
I will add here fille of eeprom 93c56 and file of Mororola MC68HC11PH8 and if someone can tray to do reprogram of those files and make in both on 126 000 miles or something close that number.
I suspect that eeprom 93c56 file isn't good because of too many failed attempts at changing the mileage.If someone has good file for 93c56 Land Rover Discovery 2...2003year and will share with me I will appreciate it.
P.S I successfully read and did reprogramming with DigiProg on eeprom and Motorola ( put 126103 on both ) and when I return all back on the car it start out normal and then after two seconds it starts flashing again and I also can't change kilometers to miles.![]()
In the link that gave You @clusters are the photos of every adapter for DIGI look there and download it !!
digiprog-ST48-pinout.jpgNissan Navara / Pathfinder HCS12 check ST48 adapter pinout mine white and brown pin 7 and 13 was wrong way around opened up db25 conector and soldered correctly works 100% afterwards - see correct pinout
ST 48 yellow 18 yellow
green 17 green
white 7 white
brown 13 brown
'If I helped, please click Thanks +Reputation..!'
memet99600 (20th January, 2017)
has anyone used digi to do 2013 mercedes a class w176 dash obd?
Stop getting worried about what could go wrong, and start getting excited about would could go right!
hmmmmmmm........eeprom
Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
yes works. (but not sure if all versions work)
but you need to use a canfilter first
honingkoning (22nd January, 2017)
then best to do eeprom. cluster has to be removed anyway.. (quite easy exctually for this car.)
