Page 401 of 462 FirstFirst ... 301351391396397398399400401402403404405406411451 ... LastLast
Results 6,001 to 6,015 of 6927
  1. #6001
    Mar 2016
    Quote Originally Posted by clusters View Post
    Yup, that's the HC11, better off with UPA USB on those or a different programmer capable of reading them.
    Thanks for confirming. Do you have good site that i can buy upa usb.
  2. #6002
    clusters's Avatar
    Mar 2015
    Canada
    Nope, shop around but worth it to buy original UPA-S, not a clone.
  3. #6003
    Jan 2016
    twingo 2003 vdo. cable 34. worked fine.
  4. The Following User Says Thank You to mileage1 For This Useful Post:
    dritan (2nd February, 2017)
  5. #6004
    honingkoning's Avatar
    Dessert
    up to 2002 is HC11, 2003 up is 9s12. Post a picture of the back of the board.
    Not true mate 2003/2005 is eep 24c16
    After 2005 is 912.
  6. #6005
    Mar 2016
    Quote Originally Posted by honingkoning View Post
    After 2005 is 912.
    So can my 03 be done with digiwigy and how? Do u have pinout?
  7. #6006
    Dec 2016
    City of Angels
    [QUOTE = letalcrudo; 2706931] a minha experi?ncia com digi 4,88
    Chevrolet Corsa obd ok (depois de desligar a bateria por alguns segundos)
    Vw AMAROK 2012 OBD ok 1 min
    Opel Astra 2000 OBD ok
    Chevrolet Montana OBD ok
    Chevrolet Cruze 2011 OBD ok
    Chevrolet Cruze 2012 OBD N?o funcionou. Remover BCM ao lado do assento do passageiro do p? esquerdo voc? encontrar? 24c16 ok [/ QUOTE]
    Letalcrudo, Montana did you select which car? I have v4.94 and I can not find it, it is 35080 or 35160, if it succeeded by obd it was which year of Montana?
    If anyone else knows, help me, thank you.
  8. #6007
    South Africa
    Would also like to know which car was selected for Chevrolet Montana. Have a 2012 i need to do.
  9. #6008
    Jan 2017
    Can i connect to pc to transfer eeprom data from and to digiprog?
  10. #6009
    Oct 2015
    Quote Originally Posted by zix1 View Post
    It depend on if you FTDI chip inside, you can, if you don't have ftdi chip you can't connect to PC
    If I help you don't forget thanks button
  11. #6010
    Jan 2017
    Quote Originally Posted by memet99600 View Post
    How do i find out?
  12. #6011
    Jan 2016
    How do i find out?
    see image for chip.
  13. #6012
    Jan 2017
    No it doesnt (((((
    Could i buy one and solder it on top?
  14. #6013
    ascrap2003's Avatar
    Sep 2016
    Texas
    I have a digiprog 4.88 coming in should I modify it when it arrives? resolder joints on board etc? read or back up any files? replace connectors?
  15. #6014
    Sep 2015
    northern ireland
    2009 audi a4 b8 reads miles but won't write new miles trough obd
    Sent from my SM-G900F using Tapatalk
  16. #6015
    autocargo's Avatar
    Hello. My digiprog not booting anymore... I suspect the problem is CY7C1049d-10VXI memory as found in many cases. Fault has started randomly not booting but after repeatedly power on/off would finally boot... Now looking at mouser website to order replacement chips but this part no longer available... there is other parts (quite a few) but not sure witch one is compatible. Nearest by numbers is CY7C1049G-10VXI... I was comparing datasheets and looks identical, but still not 100% sure... Any recommendation, maybe other producer that has been tested and 100% compatible? Thanks in advance.
