Page 402 of 462 FirstFirst ... 302352392397398399400401402403404405406407412452 ... LastLast
Results 6,016 to 6,030 of 6927
  1. #6016
    Oct 2015
    Quote Originally Posted by autocargo View Post
    Hello. My digiprog not booting anymore... I suspect the problem is CY7C1049d-10VXI memory as found in many cases. Fault has started randomly not booting but after repeatedly power on/off would finally boot... Now looking at mouser website to order replacement chips but this part no longer available... there is other parts (quite a few) but not sure witch one is compatible. Nearest by numbers is CY7C1049G-10VXI... I was comparing datasheets and looks identical, but still not 100% sure... Any recommendation, maybe other producer that has been tested and 100% compatible? Thanks in advance.
    http://www.newark.com/cypress-semico...rfnonsku=false
    If I help you don't forget thanks button
  2. #6017
    Sep 2015
    Is it possible to update original Digiprog3 from version 1.32 to 4.94?
  3. #6018
    Jan 2016
    Insignia 2009 -> acces denied (x-tool work ok)
    porsche 997 gt3 2008 obd ok.
  4. The Following User Says Thank You to mileage1 For This Useful Post:
    dritan (8th February, 2017)
  5. #6019
    Jan 2017
    IN CIRCUIT
    Car 2014 VW Tiguan Diesel OBD2 OK DIGIPROG 3 CLON
  6. The Following User Says Thank You to harold1987 For This Useful Post:
    dritan (20th February, 2017)
  7. #6020
    ascrap2003's Avatar
    Sep 2016
    Texas
    Hey do you know a good book or course to steady circuit/electrical schematics to learn to read them what the symbols all mean and all that? Or maybe you can teach me I shall call you obi won
  8. #6021
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    Fiat grande punto 2012 obd with (fiat doblo 2007->) read ok write ok
  9. #6022
    Mar 2016
    Has anyone tried lexus rx450h 2016 with digiprog ?
  10. #6023
    Aug 2015
    BEHIND YOU
    Quote Originally Posted by Jp4ubaby View Post
    read eeprom and post dump and i will give you the desired mielage
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  11. #6024
    Mar 2016
    Quote Originally Posted by eliaselias View Post
    Hey i dont know how to upload dump to site. Im beginer learning. I dont if my clonw 4.94 can connect to pc. I have only done cars with programers only.
  12. #6025
    Aug 2015
    BEHIND YOU
    tell me wich mileage you need to make the file for you
  13. #6026
    Mar 2016
    I dont have the car yet. Ill get it end of week. Im just asking you guys if it can be done with digiprog.
  14. #6027
    ohkarol's Avatar
    Oct 2010
    PL/UK
    anyone did audi a3 2011 with digiprog ?
    bFlash/Kess/Ktag/CMD Master
    DPF/EGR/DTC/AdBlue/ChipTuning. ------>PM
  15. #6028
    Nicolas9's Avatar
    Feb 2017
    Aruba
    yes works fine.
    use the diag -2012 option.
    of dash goes black. then do the same again.
  16. The Following User Says Thank You to Nicolas9 For This Useful Post:
    ohkarol (22nd February, 2017)
  17. #6029
    DK Veteran chiptorque's Avatar
    Nov 2010
    Hello, with Digiprog 3 4.94 I have a doubt with the MB class C W204 year 2013, I do everything Tacho and EZS for OBD but they come out of the KM that I had. And when I enter ASSYST it takes to read tells me to modify days, I cancel it and then KM but it does not read what it has and I do not know which ones to put. Do you know the procedure? thanks and regards.
  18. #6030
    Nicolas9's Avatar
    Feb 2017
    Aruba
    put a can filter. and do tacho diag again
  19. The Following User Says Thank You to Nicolas9 For This Useful Post:
    chiptorque (23rd February, 2017)
