Page 406 of 462 FirstFirst ... 306356396401402403404405406407408409410411416456 ... LastLast
Results 6,076 to 6,090 of 6927
  1. #6076
    Aug 2015
    BEHIND YOU
    Quote Originally Posted by ajcosta1 View Post
    Need help
    I buy a Digiprog but doesn?t work in k-line and Can bus cars.
    Anyone have ideas?
    hello how are you ... in which car it did not worked?
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  2. #6077
    Feb 2015
    Quote Originally Posted by eliaselias View Post
    GOLF IV K-line
    TOLEDO I 2001 K-line this has been tested with VAg TACHO in past and worked well
    A3 8p 2006 CAN
    In all three have the no connection error
  3. #6078
    Mar 2017
    Same as i buy from obd2cartool, this price is too much. v4.94 is a clone one, for me it is ok. digiprog orignial more than 1000usd.
  4. #6079
    Sep 2015
    northern ireland
    Hi. .. my digi 4.94 has started messing about.. first problem was 2009 b8 a4. Doesn't read old km and doesn't change km but still asks to check written value. (Worked on a b8 in the past) other car was 2004 told didn't read old value (?) And again didn't write new value.. select a golf of the same year and didn't read old value (? Again ) but did write new value. Then today I tried 2003 bora and doesn't read old value and when writing is says something like read backwards from 0fff 0x0. And doesn't write... have had this tool over a year and worked perfectly on 100s of cars reading old and writing new without problems. Anyone had the same problem? Maybe soldering or bad chip? Always been stored in a shock proof case.
    Sent from my SM-G900F using Tapatalk
  5. #6080
    Mar 2017
    Hi,there has somebody do hyundai i30 2016 KM successful?
  6. #6081
    Newbie centralinas's Avatar
    Oct 2015
    Lisbon,Portugal
    Hi,can you spare the code for gal,mine dead,got new one but no code for it,please,thanks.
  7. #6082
    Apr 2017
    Hi, anyone have experience with BMW E60/E61 year 2007 CAS3?
    What about 2008-2009 CAS3+?
  8. #6083
    XmoDDeR's Avatar
    Mar 2011
    putting salt on leeches, one grain at a time!
    if updated u would have better luck making yellow snow in sibera
    Reading is fundamental, asking is easy............................
  9. The Following User Says Thank You to XmoDDeR For This Useful Post:
    shirokov (1st April, 2017)
  10. #6084
    Feb 2017
    United States
    2006 Sierra
    This is where im supposed to hook my clip on correct?
    I went through my list on my manuals under Chevrolet but have not yet found it showing exact location.
    What type is the chip to read it? I know its a alcatel 25020 chip.
    Im still fighting to get my tool to work in circuit but i can desolder if need be. Can i program hours as well?
    Thanks Guys
  11. #6085
    clusters's Avatar
    Mar 2015
    Canada
    Yes that is the right chip, use Avalanche to program the mileage. Then Hummer H2 -2007 for the hours. It's an S95P02.
    Search the forums for Silverado and you will find tons of info.
  12. The Following 2 Users Say Thank You to clusters For This Useful Post:
    Joeyfast13 (1st April, 2017), Music73 (17th April, 2017)
  13. #6086
    Feb 2017
    United States
    Thanks clusters. I defiantly did look but but all I found was the silverado clusters with the shift indicator readout when I had the light indicator! Just wanted to make sure as I couldn't find it in my manuals! Is there a guide that tells me what type to read different eeproms?
  14. #6087
    Jan 2017
    Hey guys,
    I would like to do a w203 from 2000 with DP3.
    Correct milage with st60 is enough or has to be done more steps? Like ignition or ezs...
    It doesnt have to be a clean job. It just needs to show corrected milage in cluster.
  15. #6088
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by zix1 View Post
    Hey guys,
    I remember you in a E46 topic, telling the helping guys that No one gives good answers to your question !!!!
    So No help from me.
    Good luck
  16. The Following User Says Thank You to honingkoning For This Useful Post:
    memet99600 (10th April, 2017)
  17. #6089
    Jan 2017
    Quote Originally Posted by honingkoning View Post
    So No help from me.
    Good luck
    yes but it was my fault because I was confused about the procedure. Since I ve done some BMWs now, I understand a little bit more about the work.
    Don't be mad, everybody speaks and understands English in a different way. We aren't all native english people. So sorry mate.
  18. #6090
    Oct 2015
    Yes you're right it's your fault, people want to help you and answer to your questions but if you change you question all 5 minutes we can't help you. Use search function and you will see a lot of result for this car !
    If I help you don't forget thanks button
