Page 412 of 462 FirstFirst ... 312362402407408409410411412413414415416417422 ... LastLast
Results 6,166 to 6,180 of 6927
  1. #6166
    Apr 2017
    Good morning guys
    This morning i try to use this digiprog that i just bought and now once i plug it to the ac outlet the screen is blue or whatnot but once i plug it to the obd2 work fine but can't do anything with it so once i bring it back to the house and plug it again to the ac outlet does work pass the first screen but screen display is all scribble and can read anything and sometimes stays frooze please need help guys thanks
  2. #6167
    antenor's Avatar
    Here
    Fu**ed by the Chinese
    If i help, d'not forget to press thank button!!
  3. The Following User Says Thank You to antenor For This Useful Post:
    mushroomhead128 (2nd June, 2017)
  4. #6168
    Oct 2015
    Quote Originally Posted by mushroomhead128 View Post
    Good morning guys
    Only 1 solution, resend to china for repair, this is the best solution
    If I help you don't forget thanks button
  5. The Following User Says Thank You to memet99600 For This Useful Post:
    alle bmw (14th January, 2018)
  6. #6169
    instead of resend to china i would buy a new one.
    think is same price range.
  7. #6170
    Oct 2015
    Quote Originally Posted by vageric View Post
    It depend on country, I pay only 20$ for sending
  8. The Following User Says Thank You to memet99600 For This Useful Post:
  9. #6171
    Has anyone done a 2009 vw Passat with red dash using dp3 clone via old??When reading mileage dp3 clone reads about 40k miles less than what's on the car.Just wondering if it's safe to adjust???
  10. #6172
    Apr 2017
    guys well update the issue is fix i was researching and checking and my issue was that i was using a extension cord to be longer to my bench so for that was not getting enough power in the unit and was giving me the issues. now can someone guide me with what plug and how i have or can do ford 150 from 2005-2010 range please show me a diagram of how please that will be good as well of where to soldering around and all that thanks
  11. #6173
    sida's Avatar
    May 2014
    System32
    Quote Originally Posted by AudiS4 View Post
    How can be safe to write it if is not good read? Usually work, read good-write good
  12. #6174
    Apr 2017
    guys i need help with a 2010 Ford flex sel need to see how to do this one with the digi please thanks
  13. #6175
    Mar 2017
    I don't see that ford model in the manuals.
  14. #6176
    Apr 2017
    Quote Originally Posted by wokcz View Post
    thats why anyone can help on that please am in a urge of that one please thanks !!!
  15. #6177
    Mar 2017
    You could try other ford models from the menu, if it reads correct, then I would try to adjust it, otherwise, dont risk it. Or either read the eeprom manually or find a dump from the same model, check the algorithm, and see if it matches any other algorithm that digiprog supports.
  16. The Following User Says Thank You to wokcz For This Useful Post:
    mushroomhead128 (7th June, 2017)
  17. #6178
    Jan 2017
    HongKong
    Why not found a high quality with original and new CPU chips of Digiprog 3? it is will save much of your time.
  18. #6179
    Jan 2017
    Audi TT 8n 2005 did not work by OBD. Entered new milage, reads old milage, stick out secure plug but still old milage.
    Any suggestions?
  19. #6180
    Nov 2015
    Hi Guys!
    Because, my digiprog3 4.85clone can't connect on usb with the pc, but i have a upgrade files, - then if can i upload the upgrade file directly to 28f800? And it will work?
    And. If I have 590c8f0e0000 serial number, where and which is the format can i find in the dump? - Because i would like try my update files in news flash ic writing, because any wrong, then i can soldered back my original flash ICs. Or where need check my serial number?
    Thanky You!
