so friends here i am again,.
step by step learning new things ! ,
have done few cars allready with succes
i have a new quisten, does there exist some soldering pin out file's
because i am wondering how to find out where i need to solder because all that easy obd adjusment getting bored :P
i try'd a opel vivaro with the original clip ?( to put on the dash ) but it didnt work, and i have talked with some one from here ! en he told me that i need to soldering ?
same also a mini cooper didnt work with obd, also need soldering, but where can i find the instructions does there exist a sort of instruction quide ?
anyway Muchhh thanks for the people who i spoke and helped me with there knowlegde !!
alperstyl (12th January, 2018)
hi antenor, thanks for your reply, so can you tell me what the other site's i also can look because this the first best site i found , and i am VERRY HAPPY with all the helpfull reply's from all of you,
so if i make a picture of the taco from te opel vivaro
can someone adjust and show me where i can solder the cable's
( i try the connector ) from digipro 3, but it didnt work'd
i try it on few chips where the clip go on but not one worked, and NO i didnt kill the taco it still works, hehehehe
Hi to all! Can you give some info about: can Digiprog vers. 4.94 read seed key from Audi A6, 4G, 2011 year? Any valuable info is very helpfull. Many thanks in advance!
I think you’ll find that on the vivaro you will require you to remove the (think 93c66) eeprom from the board to read and write.. also reset the service indicator before because sometimes they won’t reset after a lower mileage has been programmed to cluster..
Sent from my iPhone using Tapatalk Pro
alperstyl (14th January, 2018)
Digiprog mostly ~~~~s up this car. So better leave it alone.
Moldovan1 (13th January, 2018)
if someone needs info about how to, i got all car file/s ( in rar )
where to solder or put the clip on chips. after long talking with the dealer, i got a mail with dp3 manual , it is in german
VW Caddy 2010 Can Micromas + 24c32 digiprog correct? Tried "No connection" writes, here I do not understand either my device is defective either digiprog will not master
@SANCHELO
Your Digiprog is Defect.
Digiprog can do VW Caddy 2010 without Problem ;-)
SANCHELO (17th January, 2018)
