Page 433 of 462 FirstFirst ... 333383423428429430431432433434435436437438443 ... LastLast
Results 6,481 to 6,495 of 6927
  1. #6481
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    I used iprog+ mate for new car dash which has a FUJITSU MICRO inside..
    Quote Originally Posted by Moe1988 View Post
    What do u use for new models ?? Japanese and korean cars ?
    Sent from my TA-1003 using Tapatalk
    Sent from my SM-J710GN using Tapatalk
    if you think i helped youkindly press REP+THANKS button
  2. The Following User Says Thank You to jjservice For This Useful Post:
    Moe1988 (21st July, 2018)
  3. #6482
    Jun 2018
    [QUOTE = jjservice; 3331025] Utilicé iprog + mate para el nuevo tablero de instrumentos que tiene un FUJITSU MICRO dentro ..
    Enviado desde mi SM-J710GN usando Tapatalk [/ QUOTE]
    hello friend the iprog + that you used for micro fujitzu. I'm from Peru as I get it if it's clone or it's original if you can help me something sure it works thanks
  4. #6483
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    just post it here anyone can help you thats why they created this...
    Quote Originally Posted by tecnicarlm View Post
  5. #6484
    Jun 2018
    England
    Will astra vxr 2008 work with this?
    Thank you
    Paul
  6. #6485
    Jun 2011
    Northamptonshire, UK
    Quote Originally Posted by paulsta View Post
    Thank you
    Paul
    You can do.. but these have chip to be removed and replaced or if very lucky you may have a erasable 35080 in it rather than a 0dwq..
    Sent from my iPhone using Tapatalk Pro
  7. The Following User Says Thank You to Music73 For This Useful Post:
    paulsta (28th July, 2018)
  8. #6486
    Jun 2018
    England
    Quote Originally Posted by Music73 View Post
    Thanks, will opcom do this without removing,?
    Sent from my Pixel 2 XL using Tapatalk
    If i helped please press the thanks button
  9. #6487
    antenor's Avatar
    Here
    To do dash you need a new eeprom to do with DIGI or R270 eraser !
    ECU have mileage. Carprog can do it!
    If i help, d'not forget to press thank button!!
  10. The Following User Says Thank You to antenor For This Useful Post:
  11. #6488
    Sorry if i'm being naive but is digiwigi and digiprog the same thing? Do you get a in circuit msop8 adapter with these?
  12. #6489
    Feb 2012
    Can you modify the kmts of a passatcc 2008 by obd?
    thank you very much
  13. #6490
    Dec 2017
    Depends on your tool but not possible with Digiprog3
  14. #6491
    swearee
    Guest
    Is it okay to use?
  15. #6492
    Mar 2013
    Europe
    You can use Digiprog with EEPROM clip read and write
    your eeprom data you can transfer to pc and edit and transfer tp Digiprog back and write with eeprom clip back
  16. #6493
    Top Poster zapdus's Avatar
    Jan 2017
    Quote Originally Posted by mushroomhead128 View Post
    Good morning guys
    This morning i try to use this digiprog that i just bought and now once i plug it to the ac outlet the screen is blue or whatnot but once i plug it to the obd2 work fine but can't do anything with it so once i bring it back to the house and plug it again to the ac outlet does work pass the first screen but screen display is all scribble and can read anything and sometimes stays frooze please need help guys thanks
    Hi, I had a similar problem
    My digiprog turn on with blue screen (no update, no issues)
    The next day I plug 12V the same way and it just turns on np
    This is my pcb
    https://mega.nz/#F!wNpXzJaB!2uN5yJACDQ4lDBVd-qGMEg
  17. #6494
    Jul 2018
    hello
    can i do VW CADDY 2016 WIth digiprog
    i did yesterday caddy 2013 WITH DIGIPROG BUT WITH Touran
  18. #6495
    Jun 2011
    Quote Originally Posted by Anass GM View Post
    hello
    I reckon you'll be lucky to do that with a digiprog clone..
    Sent from my SM-G935F using Tapatalk
