Page 435 of 462 FirstFirst ... 335385425430431432433434435436437438439440445 ... LastLast
Results 6,511 to 6,525 of 6927
  1. #6511
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by Joeyfast13 View Post
    I need help with a 09 Nissan gtr. Can I change millage with my digiprog clone and does anyone have the location of the eprom chip? Thanks in advance I mainly just do Chevrolet trucks
    solder wires on the back. easy
  2. #6512
    alclot's Avatar
    Melee Island
    Hi mates,
    I have valeo bsi with 95160 which I would like change km and clone dump in donor one but with upa doesn't write well by pinout on board. Can I do that well with digiprog?
    Car is a Peugeot 307.
    Thanks in advance
  3. #6513
    Feb 2017
    Baltic
    valeo bsi works ok with digiprog, use adapter 47
  4. The Following User Says Thank You to mikkhh For This Useful Post:
    alclot (10th September, 2018)
  5. #6514
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by alclot View Post
    Hi mates,
    Thanks in advance
    Or set upa to 3.3 V and Will be ok.
  6. The Following User Says Thank You to honingkoning For This Useful Post:
  7. #6515
    alclot's Avatar
    Melee Island
    I did that and it reads ok but read after write dump doesn't change. The original dump I modifiqued by nyo 4.0.
    Do you know how to do it well?
    Quote Originally Posted by honingkoning View Post
  8. #6516
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Howzit need advice please on 2011 VW Golf6 1.4 TSI did not know if it was MM or VDO cluster - used digiprog dash diagnostic until 2012 read 100% 234000km write 228000 needed 158000 dash went black and restarted tried a few times like it reads 158000 although dash shows 228000km then i write again to 155000 stays on 228000 it shows - car starts drives adds mileage on tripmeter etc. some funny sign displaying when driving looks like a speed control sign
    Any suggestions will be appreciated
    'If I helped, please click Thanks +Reputation.. !'
  9. #6517
    May 2015
    My Tool Room
    Quote Originally Posted by danihaos View Post
    Today I try golf 6 with dash mm9rm10 read good mileage(174000) and decided to go for write put 164000 but the dash jump at 172000(car start),disconnected battery no change,read mileage again digi read 164000 but dash show 172000 drive 3km read again and digi read 172003. Any value I put dash jump at 172000.
    ever found solution for this dash with digiprog ?
  10. #6518
    Sep 2015
    It won't go with digiprog. I did this type of dash (MM7) with X-tool.
  11. The Following User Says Thank You to sendreq For This Useful Post:
    rtbdiagnostic (12th September, 2018)
  12. #6519
    Mar 2013
    Europe
    Digiprog 4.94
    VW UP 2013 ---> OBD Work 2min.
  13. The Following User Says Thank You to bersch8688 For This Useful Post:
    chcp (20th September, 2018)
  14. #6520
    May 2015
    Someone try bmw 330 xi 2006 with digiprog? I have the car in menu but i’m afraid to try bmw with digiprog
  15. #6521
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Berubeg View Post
    Use r260 for CAS and r270 for dash
  16. The Following 2 Users Say Thank You to teerak2uk For This Useful Post:
    Berubeg (20th September, 2018), Nicolas9 (20th September, 2018)
  17. #6522
    Jun 2011
    Northamptonshire, UK
    You can’t do these via obd..
    You need to remove cluster, read and save 35080 and either replace with new or try to reset with r270( as Terra mentioned).. then rewrite saved data with new valve..
    The cas I use r260 but I have been told that the r270 can do the cas aswell but I prefer the 260 it seems more stable..
    I haven’t tried using digi to do the cas as I don’t trust it but it may possibly do it if you haven’t got the above tools but worth the investment if your gonna to do more
    Sent from my iPhone using Tapatalk Pro
  18. The Following User Says Thank You to Music73 For This Useful Post:
    Berubeg (21st September, 2018)
  19. #6523
    May 2015
    My Tool Room
    Quote Originally Posted by sendreq View Post
    There are 2 types of MM dash in golf6
    MM5 & MM7
    One of them is NEC + 95320. Digi won't work here.
    can digiprog version 4.94 do this golf 6 nec 95320 dash in any possible way
  20. #6524
    May 2015
    My Tool Room
    can it be done by opening up cluster in any other way than obd maybe nec 95320
  21. #6525
    Sep 2018
    Hi all.
    I need help with Volvo v70 2005, i have solderd and colour code converted adapter 51 and also tried with 48, i get "INIT ERROR", i have check and re-checked connections but cant find anything.
    Do i need to connect the dash to car and then do Digiprog?
    Do i need to program the digiprog unit by PC or so before using it?
    I have also tried HC12 and HCS12 both give same "INIT ERROR"
