Desolder and clean chip.
hi! Anyone have a repair solution to be able to read Motorola 05H12? thankyou very murch!
letalcrudo (11th October, 2018)
Hello everyone,
I need help for toyota prius mk2, i've just open a new thread for that here: http://www.digital-kaos.co.uk/forums...ection-(93CS66)
So if somebody know how to do that it would be wonderful !
thanks in advance
Citroen C5 2003 Sagem BSI- changing mileage, ok. I tried the dashboard (HC08) with plug 42, no luck. I checked the pinout first and that seems correct. I had four connection attempt and failed all the time. I'm going to get Carprog to do the dashboard. Anyone has success with CP (clone obviously) on this? Thanks
Last edited by nagy592; 15th October, 2018 at 09:29 PM. Reason: Missing information
Hi, somebody successfully did a 2015 fiat scudo (same as Peugeot expert/ Citroen jumpy dispatch/ Toyota proace)? Customer installed and used JC bsi and now car has more mileage and need to downgrade it. Never used this tool, and a friend let me his tool to make the job.
Enviado desde mi SM-G960F mediante Tapatalk
These are ok with digi..
95128 in the bsi.. it is covered in lacquer.. so need to remove that first.. can be done on the board but safer to remove.. you need to do dashboard also which is a 25020 I think... but again digi can do no problem..
Sent from my SM-G935F using Tapatalk
Jeep grand Cherokee 96 with digi (4.85) ok.
Hallo mates
My digi work kline and can ok but eeprom Read bad. What with it ? Any Solutions?
Wysłane z mojego SM-G390F przy użyciu Tapatalka
Yes. I just bought a new one. They’re so cheap now.
