Page 445 of 462 FirstFirst ... 345395435440441442443444445446447448449450455 ... LastLast
Results 6,661 to 6,675 of 6927
  1. #6661
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by jacekzam78 View Post
    Hi someone have updete for digiprog 3
    SN/ EDF4FD040000
    I try repair my old digiprog 3 blue screen
    Thanks.
    Remove chips read them in a programmer and write it back on a new chip and your tool will be alive again.
    No need to update
  2. The Following 2 Users Say Thank You to honingkoning For This Useful Post:
    jacekzam78 (17th March, 2019), rtbdiagnostic (13th March, 2019)
  3. #6662
    alclot's Avatar
    Melee Island
    Hi mates,
    I have one Porsche Cayenne diesel M059E year 2011. I would to change km here but I don’t which units I need to do and it dp3 can do it. Has anyone experience with it?
    Thanks in advance
  4. #6663
    Feb 2017
    UK
    hi thanks for reply I did it,I read but the first one chip is empty and I think it is corrupted
    Maybe someone has old file with this S/n number ?
    SN/ EDF4FD040000
    Thanks.
    No need to update
  5. The Following User Says Thank You to jacekzam78 For This Useful Post:
    makadam (29th August, 2019)
  6. #6664
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    2012 Nissan Qashqai with HC9S12 see image attached is it possible to program dash with digiprog 3 4.94 with plug 48
    'If I helped, please click Thanks +Reputation.. !'
  7. #6665
    Feb 2017
    United States
    I need to know if I can use my digiprog to do milage on 2009 Ford f150 platinum. So I read it's a 24c16 eeprom. Anyone have pics of which eeprom it is?
  8. #6666
    Feb 2019
    Germany
    Quote Originally Posted by Joeyfast13 View Post
    You need Cable 48 / ST48
    Open the Cluster untill you see the back of the Board... on the right corner down you see 6 small points.
    Conntecting Cable / ST48 to the 6 small points:
    From Left to right at the TOP: RED - GREEN - WHITE
    And from left to right on the down: (only one cable) YELLOW
  9. #6667
    Feb 2017
    United States
    I sure wish I could find a actual manual of what I need to do for each vehicle instead of asking. Thank you kennovic
  10. #6668
    McDowell's Avatar
    Feb 2019
    Zamunda
    Hello guys,
    I am trying to read E36 BMW 320 via digi3, I am getting and error message (see pic below), I am using connector 26 as per the PDF says, do you know if I am doing something wrong or just this tool is not working at all?
    I have tried both E36 DIAG CAN options.
    IMG_20190409_181126.jpgIMG_20190409_181133.jpgIMG_20190409_181140.jpgIMG_20190409_181151.jpg
    I would really appreciate some help with this
    Thanks!
  11. The Following User Says Thank You to McDowell For This Useful Post:
    alclot (9th April, 2019)
  12. #6669
    Jul 2018
    NZ
    Hi guys,
    Who has done an e90 cas 3? bit confused on the procedure.
    Can the Digiprog 3 only change cas km?
    Does the dash need a separate tool to change kms before the cas is plugged back in?
    Are there any other control units relevant to km change and making sure it doesn't revert?
    Whats the latest version of digiprog 3?
    Cheers everyone
  13. #6670
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Scooterz View Post
    Hi guys,
    Cheers everyone
    If it reads the CAS it will change it if not it will need removing and done with R260
    Use R270 for the dash
  14. #6671
    batandball's Avatar
    May 2011
    Which ever way you do the cas dash as to be done separate
    If it works use it
    BatandBall
  15. #6672
    Leeetoyo's Avatar
    Mar 2019
    Planet earth
    Quote Originally Posted by rtbdiagnostic View Post
    I believe it is possible with digiprog 3 clone. Just make backup to bring back if it goes wrong.
    I have done one before just not sure if i didnt do it with digimaster 3..
    Verzonden vanaf mijn iPhone met Tapatalk
  16. #6673
    Mar 2012
    hello dear community, wanted to know if someone has successfully changed with digiprog 3 v4.94 china on an audi A4 year 2007 on obd the kilometer? Yesterday tried it, after it was read, the speedometer rattled and stood in dysplay Low3- 3 :-(. Did the gum still to write, but did not go, and car did not jump on. Have again joined me and I went to read, suddenly stood the old value in the tachometer, and the car ran again ... puhh :-) Is it with the digiprog on obd, I've done something wrong? Thank you for your answers and help! ,
    Gesendet von iPhone mit Tapatalk
  17. #6674
    Mar 2012
    Quote Originally Posted by moffo View Post
    Never Can help me???
  18. #6675
    Dec 2016
    central uk
    possible it doesnt recognise the version , have had it with more expensive kits that i needed to do 10 miles or so in vehicle and try again .
    just a thought maybe try a slightly different amount to input if you try 16000 maybe try 16045 just slightly different.
