Page 448 of 462 FirstFirst ... 348398438443444445446447448449450451452453458 ... LastLast
Results 6,706 to 6,720 of 6917
  1. #6706
    Default Ford Bantam Mileage
    Hi guys
    i have a Ford Bantam here for mileage with a nec on cluster. I have digiprog 3 clone and ST59 plug but it does not work, I use ford ka pinout from the manual. Is there something i am missing here or doing incorrect? Any help will be appreciated.
  2. #6707
    Killer76's Avatar
    Sep 2018
    USA
    2004 Accord. Worked. Use ST 47 cable. Accord 93c56
  3. #6708
    cotymoto's Avatar
    May 2009
    Quote Originally Posted by ascotauto View Post
    Hi guys
    Not working nec with digiprog clone
    Enviado desde mi SM-G950F mediante Tapatalk
  4. The Following User Says Thank You to cotymoto For This Useful Post:
    ascotauto (14th June, 2019)
  5. #6709
    anytool you can recommend. These asses advertise the Nec adaptor as if it works sad sad sad
  6. #6710
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    this tool works good...
    'If I helped, please click Thanks +Reputation.. !'
  7. The Following 3 Users Say Thank You to rtbdiagnostic For This Useful Post:
    ascotauto (18th June, 2019), carradio2001 (4th September, 2019), jomberykaso (19th June, 2019)
  8. #6711
    Jun 2019
    Hi my name is Kevin. I have a digiprog 3 clone and am trying to correct the km on a 2008 Chevrolet Uplander. Can someone please help point me in the direction to change the kms. As far as I know I have to take apart cluster and connect to chip but i am not sure which one or what steps to take after that.
    Thanks in advance.
    Kevin
  9. #6712
    clusters's Avatar
    Mar 2015
    Canada
    Quote Originally Posted by Kj1195 View Post
    Thanks in advance.
    Kevin
    I just know that someone is going to steal this and use it on their sites as their own with a copyright watermark but this is my own creation.
    Cheers.
  10. The Following 2 Users Say Thank You to clusters For This Useful Post:
    Killer76 (21st June, 2019), MasterCodein (29th September, 2019)
  11. #6713
    Jun 2019
    Thank you clusters,
    So I've downloaded and read your document. I am going to try it first thing in the morning. Also I have the digiprog instructions cd but it is missing alot of vehicles (the uplander being one of them). Is there another source I can obtain instructions with a better vehicle list? I work at a shop and have alot of inquiries for this but most of the vehicles that come in are not on the list.
    Thanks again
    Kevin
  12. #6714
    Jan 2019
    FTDI Chip VS VSTM Original DIGIPROG3
    What are the differences between those names ? Original VSTM is the original DIgiprog3 ?
  13. #6715
    Jun 2019
    Hi could anyone help me with instruction for correcting the mileage on a 2009 Chrysler Sebring with a digiprog3? Is it plug and play obd or will I have to do some soldering and if so to where or what chip.
    Thank you
    Kevin
  14. #6716
    May 2015
    My Tool Room
    Quote Originally Posted by skens View Post
    i did polo 2012 with digiprog. it gave error in dash.
    tried to disconnect battery didn't help. (which battery-pole is best to disconnect? min or plus or both?)
    then I tried xtool using the JC option (it was jc cluster). but can't connect. it dont change.
    hi
    not disconect! if you dash JC ! use dp3 ,put 000000,and use xtool!
    regards
    is this solution after showing error on dash ? or follow this steps first time arround ...
  15. #6717
    May 2015
    My Tool Room
    Ford Ranger with Visteon dash HC9S12 - found this helpfull article
    For km dash, you need to multiply the value to 1.609 when writing with Digiprog 3
  16. The Following 2 Users Say Thank You to rtbdiagnostic For This Useful Post:
    jomberykaso (27th July, 2019), Killer76 (1st August, 2019)
  17. #6718
    DK Veteran szuwarik's Avatar
    Jan 2011
    Hi I have problem with my digiprog work ok only by obd not read eeprom and all other. I exchange 74hc125 x3 but still not work somebady has a solution ?
  18. #6719
    May 2015
    My Tool Room
    good day need some advice - replaced screen on a digiprog 3 and damaged multilayer ceramic capacitor see image component C71 need the value of the correct replacement i.e. datasheet parameters the temperature coefficient and voltage rating or any other way to determine the value of this multi layer ceramic capacitor suggestions be appreciated
  19. #6720
    Dec 2016
    central uk
    ok away from home but son has checked scrap one i have at home for spares and he says c71 and c83 look identical if any help.
  20. The Following User Says Thank You to evss For This Useful Post:
    rtbdiagnostic (8th July, 2019)
