Have a look at this old donar board from R270 seems some of these capacitors can be the same looking at colour size and height - how can I be sure .. can i test capacitance in some way
'If I helped, please click Thanks +Reputation..!'
aventador lp700 dash 24c16 it works with digi removing chip read and write ? any success before
josevaldes0802 (20th March, 2025), rtbdiagnostic (5th August, 2019)
Hi there
Can anyone suggest whether it’s safe to work on E class WD207 2010 Model On C Class W204 with Digiprog3
As there’s no option for D207 but if I choose W204? And both dash look the same
Tanx
should be same as W212 merc E class
Happy786786 (5th August, 2019)
[QUOTE=Happy786786;3634164]Hi there
Tanx
it's safe, don't worry/..,,,,,,
Yes
I have a 03 & 04 Ford F250 Clusters
Pretty sure its a hcs12 chip i need to correct mileage on with my digiprog3
My question is which plug do i use 48 or 51. I have already crosses over the wire colors to make sure i used the right ones.
Any Pic would be great!
Also what are the 3 white wires they are showing in the instructions
I assume I dont need the 3 white wires?
All the info you need has been posted before, you have a lot of reading to do.![]()
Will continue but I have cross search the entire forums section
Sent from my Pixel 2 XL using Tapatalk
Tried digiprog3 OBD2
