Page 452 of 462 FirstFirst ... 352402442447448449450451452453454455456457 ... LastLast
Results 6,766 to 6,780 of 6927
  1. #6766
    Dec 2019
    Hey guys, I have a VW Golf 4 1.4 1998, I wanted to apply the digiprog 3 and in the end it says "Information: Pull Fuse". Does somebody knows which fuses I should pull? I used "DIAG and until the Information Pull Fuse it canīt even read the old mileage, on the right side there are only 3 question marks.
    Thanks for any help,
    Jenny
  2. #6767
    DK Veteran gjuzel's Avatar
    Nov 2011
    (North Macedonia)
    Psitive batr 1 minute
    Sent from my Redmi 5 Plus using Tapatalk
  3. #6768
    Nov 2011
    (North Macedonia)
    Not see km.. Is ok put new and positive batt remove 1 min
  4. #6769
    Dec 2019
    Remove the positive pole for 1 minute?
  5. #6770
    Nov 2011
    (North Macedonia)
    Yes
  6. #6771
    Dec 2019
    It didnīt work, after remove the positive pole, all is black, I connect it after 1 minute and do it again and he says again "Information: Pull Fuse".
  7. #6772
    Dec 2019
    Does anybody know which fuse I must pull with Digiprog3 in a Golf 4 1.4 1998?
  8. #6773
    Nov 2012
    Croatia
    Quote Originally Posted by Jenny Eurekt View Post
    remove battery for sec
  9. #6774
    Dec 2016
    central uk
    i believe you put mileage in you require then remove battery terminal for 1 minute
  10. #6775
    Mar 2015
    Dash fuse red 5 amp.
  11. #6776
    Mar 2016
    Roomster 2007 with a odo
    5J0920840C
    can be done?
  12. #6777
    Mar 2016
    Quote Originally Posted by Madol1 View Post
    5J0920840C
    can be done?
    Done yester day by diag. Cant read from dashboard km but write original succesfull
  13. #6778
    Jan 2020
    Good night, as the clamp that comes in the digiprog is of very poor quality I bought one like the one in the photo. Is it possible to connect it to the 01/04 switch and thus not have to cut it and solder it to the other connector? regards170722001950221661.jpg71wmLEhVPIL._SY355_.jpg
  14. #6779
    Jan 2018
    thanks really works on my clone.
  15. #6780
    Jan 2018
