Edvinas111 (21st February, 2020)
Anyone had the dp3 clone not see bin files after transfer from pc?? I am having this issue wondering if there is something I am doing wrong?? anyway to restore back to factory settings??
So I tried a 09 gmc sierra cluster. It will take mileage fine but will not take hours for some reason. I have tried this with the 2007- hummer h2 option no change. So I tried it in the eeprom menu on the digiprog using tachosoft still no change. Any ideas? I've done several other 07 up gm trucks and had luck except this one.
They moved the hours in later years, the mileage is exactly the same
2007-2008 @ address 0236-0241
2009 up @ address 0000-000b
Tachosoft calculation for any GM truck 95080 is fine for the later years hours, the calculation did not change, just the location in the file.
so you have to do it manually. I hope you saved an original copy, because you corrupted a data area trying the hours with Digiprog
Joeyfast13 (5th March, 2020)
so digiprog cant do 09-up? so i can use the same hex just in different area?
clusters do you have a dump for 09 gas engine with 6 speed transmission?
Open your own help thread instead of polluting this one please. And post your file so it can be repaired.
Hello, I have a problem. First time I tired remove chip 93c66 from nissan qasqhai 2009 cluster. Then pluged chip to connector ST01 get error "CHIP NOT FOUND". After that inspected connector with the photo in internet and noticed that my connector red wire is connected to another side. Can it be bad connector or i did something worng ? here photo of my ST01. I tryed read chip car>nissan>qashai>c66 or hcs12> c66 > ST01 plug > getted "chip not found"
After that I thinked my chip burned... so i solider back to cluster insert back to car and cluster is ok km is showing normaly nothunk changed. thanks god. Its possible to burn chip if connected worng ?
Maybe i can use connector ST01&04 but that to chosse in menu ?
https://prnt.sc/rdrq07
https://prnt.sc/rdrqdn
https://prnt.sc/rdrqqr
https://prnt.sc/rdrqy7
https://prnt.sc/rdrr5p
https://prnt.sc/rdrn82 ST01&04
Edvinas111 (9th March, 2020)
sorry my english not perfect but dont understand..
I use ST01 because digi ask plug 1 and readed here better to solider down chip from cluster to prevent any damage for eeprom
I want to know its problem in connector or i did something wrong...
look difference by red wire location
My connector i found in box. >> https://prnt.sc/rdswva
>> https://prnt.sc/rdsx7b
Digi prog 3 photo of ST01 from internet >>https://prnt.sc/rdsuq5
your st01 adapter, looks like new and never soldered anything on it...
and you upload 5 pictures of clip adapter...
ok, not that you soldered the Eeprom wrong way around ...have a look at google and search for eeprom pin1 ...
Check the wiring from clip to the DB25, yes the red wire is in the wrong pin on your cable.
Picture credit to hcip.
