Page 455 of 462 FirstFirst ... 355405445450451452453454455456457458459460 ... LastLast
Results 6,811 to 6,825 of 6917
  1. #6811
    Nov 2019
    THANKS SIR!!
    So st01 and st04 wiring is the same ? as in diagram showed or I wrong at this point ? and red wire should be in same place on both connectors.
    After i fix my clip i need de-solider 93c66 chip or i can do direct connect to cluster and try ?
  2. #6812
    Jan 2020
    FRANCE
    Hello digiprog 3
    partner 2009 bsi Johnson ok dash Ok
    207 2009 bsi Ok dash Ok
  3. #6813
    Mar 2019
    hello all i got problem with my digipro3
    eeprom no read always error i check connection i check everything
    i try to read by car model it is give millions number not the real number of the dash
    what should i do??
    i need frimware??
  4. #6814
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Kimoo2000k View Post
    what should i do??
    i need frimware??
    Remove eeprom to read/write see if it's ok then
  5. #6815
    Mar 2019
    Quote Originally Posted by teerak2uk View Post
    thanks still the same no read no write
  6. #6816
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Maybe clip connection as clip they supply are pretty crap
  7. #6817
    Mar 2019
    i did and i check
    i think i damage my digipro
    because i use by fault other cable i used cable 16 pin connector in st01 location
    the 16 pin cable is for sbb clone
  8. #6818
    Mar 2019
    Hello my friends i need firmware for my china digipro 3
  9. #6819
    Mar 2019
    digiprog 3 out high volt to eeprom problem i got this the colne out 36 volt to eeprom i dont know how i can fix this can you please help
  10. #6820
    May 2017
    Hi all. I have problem with my digiprog3. I can't any read eeprom. Always is CHIP NOT FOUND. Via OBD2 with all cars good work
  11. #6821
    Mar 2019
    Quote Originally Posted by kotarski88 View Post
    me too now
  12. #6822
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Hy, audi a3 8P0 dash, do you try?
  13. #6823
    May 2017
    Quote Originally Posted by catalinosonesti View Post
    yes. 2010y good work
  14. The Following User Says Thank You to kotarski88 For This Useful Post:
    rtbdiagnostic (8th April, 2020)
  15. #6824
    Anyone run into DEF on display on 2012 Audi A8 dash??I changed the dash. The replacement is fine. This original one was faulty to begin with. all lights flicker flash very fast no gauges work. However I tried to see if possible to read and write s95320. Turns out with pogo it read s95320 and deleted however this faulty dash now displays 0 miles and DEF in trip. Anyone know what causes this issue??
  16. #6825
    Anyone know how to delete files on this?? Every time i delete a file it write new file with 1 makes no sense anyone???
