Page 456 of 462 FirstFirst ... 356406446451452453454455456457458459460461 ... LastLast
Results 6,826 to 6,840 of 6917
  1. #6826
    Nov 2018
    Anoy one have files to install digiprog in windows 7
    with drivers ?
  2. #6827
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by Chip Tuing View Post
    with drivers ?
    sure...........
  3. #6828
    Apr 2019
    Hello friends, I have a question, is the second time I do a jetta clasico (is the name in mexico from 2008 to 2015 jetta) I don't know the name in other countries, it has an 93c86 inside the cluster, I choose the T5 option and read the correct mileage, but is the second time the car had problems, the gauges don't work properly, speed doesn't go down more than 20km/h when it work until it turn off, I don't know if it has to do with a bad needle placement but I think it has to do with the information, when I see tachosoft it says the address 130 140 is the mileage storage, I see the backup I did and is similar, I think it is swap, example the backup in the lines says:
    130 XX XX XX XX XX XX XX XX XX XX DB CF DB CF DB CF
    140 DB CF DC CF DC CF DC CF DC CF
    The algo in tachosoft for T5 says CF DC in all spaces
  4. #6829
    Oct 2017
    hola, ese auto no se puede hacer con digiprog solo con la herramienta dobd2
  5. #6830
    Apr 2019
    Quote Originally Posted by manchunoe View Post
    Thanks for answer, which tool I can use to do this car?, in the past I've done some other jettas with digiprog 3 without problems, only two of them have had the problem I mentioned.
  6. #6831
    Feb 2020
    Hi everyone, can someone give me the digiprog 3 last owner's manua??
    thaks...
  7. #6832
    Apr 2020
    Hi, please help. Remault Fuence 2011. What happens if I rewrite the dashboard and ABS controller no write .
  8. #6833
    Apr 2020
    Default Fuence 2011. What happens if I rewrite the dashboard and ABS controller no write
  9. #6834
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Sure you need a canfilter to block ABS
    'If I helped, please click Thanks +Reputation.. !'
  10. #6835
    Jun 2020
    Hello guys.
    I tried to upgrade my Digiprog 3 to V4.94 but it didn't work.
    I used win XP 32 bit.
    It can't connect to digiprog.
    Any idea?
  11. #6836
    Jan 2020
    FRANCE
    citroen ds3 counter failure st 01
  12. #6837
    Jun 2020
    Hi I have never used clone before
  13. #6838
    Apr 2017
    Does anyone know why all of a sudden it causes frozen clock after changing mileage?
  14. #6839
    Jun 2020
    hello every one.
    Can any one tell me if the new Digiprog 3 with FDTI chip is good to connect USB with computers for transfering eeprom files and loading them. any help would be greats.
  15. #6840
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by stzmotors View Post
    hello every one.
    if you buy one with fdti chip, then yes it will work...
  16. The Following User Says Thank You to figani For This Useful Post:
    stzmotors (22nd July, 2020)
