Page 458 of 462 FirstFirst ... 358408448453454455456457458459460461462 LastLast
Results 6,856 to 6,870 of 6917
  1. #6856
    2014 VW touraeg will not go via obdII. Will read dash and correct mileage however 7F error displayed on dp3 clone. Any ideas??
  2. #6857
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by AudiS4 View Post
    Of course it won't buy a better tool
  3. The Following User Says Thank You to teerak2uk For This Useful Post:
    brend (8th October, 2020)
  4. #6858
    Jan 2020
    FRANCE
    Digiprog 3
    Audi sq5 2014 OBD Ok 30 min job
    Seat Léon 2008 OBD Ok
    Golf 6 OBD Ok
    Mercedes w204 OBD Ok + mb can filter
    Land Discovery 3 st 01 no work
    Advice for digiprog change st01 for 3m soick quality and scrubs soick eeprom
  5. #6859
    autocheck's Avatar
    Feb 2014
    Zimbabwe
    Honda freed 2008 with eeprom S93c76 56123km File request. mine not showing mileage
    Sent from my SM-A605FN using Tapatalk
  6. #6860
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    2011 Audi S3 dash via OBD2 anybody can share experience with Digiprog
    'If I helped, please click Thanks +Reputation.. !'
  7. #6861
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    hi
    do not try ,dash is secure .
    http://www.codecard.eu/carprog/softw.../prod_772.html
    best regrads
  8. The Following User Says Thank You to catalinosonesti For This Useful Post:
    rtbdiagnostic (19th October, 2020)
  9. #6862
    Jun 2011
    Northamptonshire, UK
    Quote Originally Posted by rtbdiagnostic View Post
    Did a standard a3 one of these and and it locked up in service mode, was a little scary.. but it did come back after going through it again.. but definitely had me touching cloth..
    Sent from my iPhone using Tapatalk Pro
  10. The Following User Says Thank You to Music73 For This Useful Post:
    epicsabi (14th November, 2020)
  11. #6863
    May 2015
    My Tool Room
    Hi I do them audi,s with clone digiprog 3 v4.94
    Read and change km on of the ignition few times then cluster dies. Unplug take out key and restart procedure from beginning. Ign on plug in redo km reads 0km enter new km u want and bam cluster activates again and changes to the new desired km ignition on off as tool says and that's it. I've done plenty of them specially 2007 to 2010 a3audi,s could be 11 as well. Never had one issue doing it that way.
    As tested by one of our members
    https://www.digital-kaos.co.uk/forums/showthread.php/483974-Audi-A3-2007-micronas-CDC3217G?p=2762492&viewfull=1#post2762492
  12. #6864
    Feb 2020
    2010 mercedes c class w204 select EZS , took 30secs mileage stuck but have to reset DPF or limp mode after a few miles
    2010 touran highline clocks 30seconds no issues
    2010 ford kuga need to clear a lot of DTCs though after correction
    seat ibiza 2010 no problem
    2006 , 2008 , audi a3 no problems
    2010 audi a3 first change went to 0 miles , second try was fine
    insignia 2009 no problems 30seconds
    2007 fiesta 30 seconds no problems
    2010 t5 vw transporter no problems
    2011 caddy no problem
    VW UP could not do
    2010 insignia could not do but obdprog m500 doctor did no problem
  13. #6865
    Nov 2012
    Croatia
    i killed one dash,blocked in boot mode,repair it with smok by obd,dash was dead,no ignition,and not start car,
  14. #6866
    Mar 2019
    Hello all,
    How are you all.
    I want to correct mileage for jeep liberty kk 2009.
    How i can do it by digiprog 3??
    Thanks in advance
  15. #6867
    Anyone know if digiprog clone will do 2000 audi TT via obd?? I have new replacement cluster and odis did not convert km to miles. Wrote too high a mileage. Wondering if Digiprog can save my ass.
    KOMBI+WEGFAHRS. M73 D56 DASH
  16. #6868
    cotymoto's Avatar
    May 2009
    No
    Enviado desde mi SM-G973F mediante Tapatalk
  17. #6869
    Quote Originally Posted by cotymoto View Post
    No
    Have you tested or tried ??
  18. #6870
    Feb 2017
    United States
    Anyone got digiprog to work on 2006 ford mustang cluster. I tried swapping power and ground on my connector. Still cant get it to read.
