Page 46 of 462 FirstFirst ... 3641424344454647484950515696146 ... LastLast
Results 676 to 690 of 6927
  1. #676
    Quote Originally Posted by justy22 View Post
    03 and 04 models done grandbcherokee and jeepncherokee both by obd
    Which OBD connector u use the one with double ends for SRI cable 17 or dongle cable 33 thanks
  2. #677
    justy22's Avatar
    May 2009
    UK
    Quote Originally Posted by javyb View Post
    I think it was 33 but will upload the latest PDF later, also never ever switch ignition with cable connected or it will fry
  3. #678
    Prussia
    That rule applies to all cars with TU, in fact always switch ign on before plugging in any obd device
  4. #679
    Meat-Head's Avatar
    Quote Originally Posted by TULGEYWOODMAN View Post
    RUMOR
    toyota avensis pin ?? of diagnostic socket has pulse from coil to it - frys struff search autel
    ON TOPIC :-
    correct me if i'm wrong, did iii sodding phone see this does airbag reset and immo stuff?
    O
    if i'm wrong - what simular devise was it?
    JUSTY, mate is the leads same quality as the carprog? meaning flexable not solid as a rock?
  5. #680
    Member spiria's Avatar
    Belarus/Grodno
    Hello.
    Who have new pdf for Digiprog? Send me pls.
  6. #681
    DK Veteran almeida's Avatar
    Hello
    Anyone try with audi A3 from 2008
    Cheers
  7. #682
    Default w212
    "hello
    i need to adjust odometer for w212 by obd : dash+ezs
    in the menu of digiprog 3 i have:
    1 tacho diag
    2 tacho 24c128
    3 ezs
    4 assyst diag
    5 assyst 24c128
    6 clr error
    what program i use to adjust the car by obd ?
    thanks"
  8. #683
    Quote Originally Posted by abdallah View Post
    "hello
    1 tacho diag
    2 tacho 24c128
    3 ezs
    4 assyst diag
    5 assyst 24c128
    6 clr error
    thanks"
    You have already asked this question and been given an answer!
  9. #684
    batandball's Avatar
    May 2011
    "hello
    1 tacho diag
    2 tacho 24c128
    3 ezs
    4 assyst diag
    5 assyst 24c128
    6 clr error
    thanks"
    EZS then assyst
    I had one last week that put the engine management light on after error clear, just use different machine to clear DTC,s code was something about DPF blocked
    If it works use it
    BatandBall
  10. #685
    wadim21's Avatar
    Sep 2011
    FIAT PUNTO 2008 OBD not work
    FIAT BRAVA 2008 OBD work
  11. #686
    Prussia
    Quote Originally Posted by batandball View Post
    EZS then assyst
    kms in dpf not match kms in odometer
  12. #687
    batandball's Avatar
    May 2011
    It happened when I used error clear, only one its done it on
    If it works use it
    BatandBall
  13. #688
    skens's Avatar
    Zagreb,Croatia
    Default dp3
    hi
    GOLF 5 2008 kombiistrument 3HL , OBD -OK 1min
    GOLF 5 2008 ECU DIAG R4 1,9L EDC 000SG OBD-ok 10min
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  14. #689
    wadim21's Avatar
    Sep 2011
    W211 ZGW not work
  15. #690
    Prussia
    nothing to do with your machine, probably something different on that car?
    done 2x 2012 w212 250 estates this week , one put light on, one didnt.
